Throttle body Size?
I have a 96 ws6 LT-1, with 3.73 gears, TSP rumbler exhaust, k&n filter and a few free mods. I will probably be pulling or gutting my cats soon. Mostlikely long tubes this summer sometime.
Now for my set up should I get the bbk 52mm or the 58mm? I plan to match up the intake manifold to it to complete the installation.
Would the 58mm be more for cars with high flow fuel injectors?
I plan to put nitrous on soon. I was planning on the 58mm. But like I said I am not sure.
Let me know what you guys think
S
Everyone else says to got with the stock throttle body. Why should I go with a 58 mm?
Now for everyone else that reads this
If I do the 58mm even if that has no benifit now. will it hurt anything.
I plan to do an lt4 conversion kit in about a year.
Thanks
Thanks
Thanks
1. The opening on your intake manifold will only accomodate a 54 mm TB without having to port the intake.
2. The 52 mm TB will flow roughly 748 CFM and the 58 mm flows in the range of 1000 CFM. For a NA 350 CI displacement engine you will have to turn 10,000 RPMS to require 1000 CFM. You would need to be turning around 7400 RPMS
3. A large TB can cause some throttle response issues due to decreased port velocity down low.
I plan to port it to 58mm.
Now as far as throttle response. This may accually make it less responsive?
would it be worth more for me to get an aftermarket MAF sensor. Or will that do the same give me to much air flow?
Thanks
Ed
It has a 48mm TB because GM makes 48mm TBs. It was an off-the-shelf part
I would be willing to bet that 502 would make considerably more hp w/ a larger TB.
Matt
There was an article long ago, that was a great write up on intake pulse tuning. it says that as long as the velocity of the air through the throttle body is less than 180fps, then the pulses from the intake ports can get out through the TB, in effect creating a much larger intake plenum. This makes for more torque until the critical velocity is reached.
If you calculate the intake velocity through the stock throttle body using David Vizard's (the guy that wrote the article) equations, it reaches critical velocity at 4800rpm, which is perfect for a stock LT1 engine. The 58mm TB maxes out at around 6500 rpm on a 350, which, again, is just about right for a built engine. 52mm TB would be good IMO
Now what about when I use nitrous will the 52 or the 58 be better?
Thanks
Ed
