jet hot sucks
Old 04-10-2005, 08:16 AM
TransAmDave96's Avatar
Default jet hot sucks
Well finally got the headers in, went in pretty easy on the driver side from the bottom, had to jack up the motor a bit to slide them in the top from the passanger. got it all bolted finally, and the passanger side rests right on the k-member, im so frustrated right now after all that work, i just want to put the manifolds back on it and sell the damn thing.
should i call jet hot and see if i can get another set? not only did they not fit, the flange is not flat, or is there anything else i can do. someone said jack the motor back up and hammer at them, i dont really want to do that though.
anything?
dave
Old 04-10-2005, 08:48 AM
SAPPER's Avatar
Send them back. and raise holy hell. I would.
Old 04-10-2005, 09:56 AM
Valkyn's Avatar
Dont hammer on them.
If they are resting on the Kmember, your motor mounts are probebly shot or something, making the engine sit lower than it should.
Old 04-10-2005, 12:09 PM
TwoFast4Lv's Avatar
This very well could be. I have had to move engines on the mounts to fit the headers.
Good luck!
Old 04-10-2005, 04:47 PM
Would the motor sag that much though? they are right up against the k-member and i have to push kinda hard to lift them off. doesnt the engine torque over towards that direction anyways? i wonder if i just got a crappy set.
Old 04-10-2005, 09:36 PM
brandboZ28's Avatar
I would bet on the motor mounts as well. There was a large visual difference between my 135k stock mounts and my ES poly mounts.
Old 04-10-2005, 10:00 PM
Thanks for the advice, i feel a little better about it. is a motor mount a motor mount? or since im at it should i get some better kind? if so, where at?
thanks
Old 04-10-2005, 10:11 PM
Birdman7389's Avatar
Go through one of the sponsors (I think I got mine from thunder or tbyrne). Get the poly mounts. As stated, when placed side by side, my stockers were pretty bad.
Old 04-10-2005, 11:04 PM
Bawls's Avatar
I agree, I've heard a lot of stories where the collector fit too close to the floor board (pacesetter) or the primaries rested on the kmember(jethot/hooker).
Poly motor mounts are only ~$50. I got prothane mounts for $50 from thunder racing.
Old 04-11-2005, 10:09 AM
aintno6's Avatar
As for your flanges not being true, I would get on their *** about that. Are you sure?
Mike
Old 04-11-2005, 11:21 AM
curlyws6's Avatar
After reading this thread, my JetHots do about the same thing. What kind of mileage do most people see problems with "sagging" motor mounts (my car has 68,000 miles)? I am happy with the Jethots except some banging under the car which could be caused by my mounts.
Old 04-11-2005, 03:57 PM
Well mine apparently are sagging i have about 75000 miles on it. aintno6, yea i put a level on the side that rubs and they are not flat at all. i hope that i was able to get them tight enough that they dont leak.
Old 04-11-2005, 04:17 PM
aintno6's Avatar
I would jus send that one back. I have heard many people say it will really increase the chances of leaks down the road.
Mike
Old 04-13-2005, 08:59 AM
BRIAN98Z28's Avatar
overtightening them will cause them to warp, dont do it.
Old 04-20-2005, 10:42 AM
Mystic97z's Avatar
i had a problem with my jet hots and they overnighted me a new drivers side header w/ no charge. seemed to be very helpful with their customer service.
-Jason
Old 04-22-2005, 04:58 PM
-PEPE-'s Avatar
-Jason
Agreed! Todd in CusServ is excellent, sending my entire set back for recoating, my engine is blown anyway so might as well make use of the down time, if it's even the coating that's bad, looks bad to me. But they are replacing the #1 primary possibly which has always leaked on me, sucking 02 and running my driver side too rich, tried every sealant known to man I think, nothing works for over a week or so.
Quick Reply: jet hot sucks
