Car is hesitating and bogging, backfiring while cruising too
and i am not sure if you can put your factory coil back on there with that crane box. i would think its ok, but i dont know. maybe the crane instructions say something about it
-I took the Crane box off and left the coil on there.. still did it..
-Changed the coil back to stock, plugged the ignition box back in, still did it.
-unplugged the ignition with the stock coil and IT STILL DID IT..
-checked all my wires, has new plugs and new opti.. Only thing could be is the ICM.
Be careful with how hard you get into the throttle. We did an accidental 180 in the middle of 2 lanes of traffic because of that problem.
Throttle body im going to try..
Tonight I changed my plugs and wires again.. I bought moroso ultra 40 race wires and a taylor opti kit and used the ovc wire looms and redid them.. What a friggin difference! I punched it once on the high way and I have to say my car has NEVER pulled that hard before.. But then i was driving home and it started to stutter again.. Only did it a TINY bit though and then i took it home.. its idleing really low and the lights are starting to dim till I rev it up a bit.. I think it might be my altenator.. im going to take it off and go have it checked today at napa.. While im driving im seeing just above the middle line on the volt gauge on the dash. I checked everywhere I could think of for a vac leak and couldnt find one anywhere.. its weird how my car just does this sometimes but not all the time.. I dont get how it could be the IAC, doesnt that only work at idle?
Yeah thats what I thought also, but it was a few things on mine. I replaced The AIC and it seemed to fix the free reving, im still chasing a miss. Tried the coil, plugs wires ect.. Bought a new opti to try that. I too looked everywhere for a vacum leak, but to no avail. Could just be your opti on its way out.
Does the check engine light come on at all? And how did you have the battery tested?If you did the test on the battery yourself with a voltmeter that would not be a proper test. I had the exact same thing happen and it through up codes that indicated the high and low frequency could not be read on the OPTI-CRAP. The battery I had was an optima red top and only about 3-4 month old but I don't drive the car very much. I took the battery into Advance Auto and had them test the battery under load. this test is better because it puts a load on it and it is not getting any help from the alternator like it would on the car. If it were running of course, plus it can be hard to put a good heavy load on the battery while it not running.
If it is tripping code do the old paper clip trick and count the times the check engine light blinks. or you could go to Auto Zone and see it they give away those free test keys and code books. That what I have. I think the code were a 28 and 36 but don’t quote me. I was about convert to a DIS ignition because I am on my 4th distributor. But all I did is put in a new battery and all was well. Now I just drive the car more to keep the battery up in check.
Also, I remember a while ago shoebox on cz28.com told me that if my alternator is going bad it can cause the car to stumble and sometimes idle funny.
I think the alternator might still be the problem, so I guess try to replace that if nothing else works for you.
Good Luck!
At night I can see a halo around the spark plugs. I think thats my problem.. Thats why I checked the grounds.. Im going to change the plugs again right now. Im trying to find the same plug as the autolite 103 but in a different brand.. I dont know what else it could be.. It couldnt be the IAC could it? That only affects idle, right?
