Help in chosing LT1 oil pump??
Old Jul 12, 2005 | 11:45 AM
350 LT1's Avatar
Default Help in chosing LT1 oil pump??
I am rebuilding my LT1 and i have stock crack shaft and stock oil pan.
What type of oil pump do i get?
Do get melling pn# M55 or M155, High volume or standard volume?
Please i need to know.
Old Jul 12, 2005 | 11:55 AM
z28boysteve's Avatar
high volume, always, the LT1 comes stock with a GMPP high volume pump anyway. dont forget to get the feed tube welded, and set the feed at the correct depth (about a 1/4" from the bottom of the pan) some doughy substance works good for measuring this.
Old Jul 12, 2005 | 01:20 PM
dhdenney's Avatar
I thought with stock pans you are supposed to use std volume? I was under the impression a high volume will pump too much oil up top and leave your bottom end dry. Just what I thought. With the 6 and 7 qt pans you got extra oil for the bottom end and the high volume works well. If the stock LT1 had a HV I didn't know it.
Old Jul 12, 2005 | 01:26 PM
97camarolt4's Avatar
I use high volume and it works great.
Old Jul 12, 2005 | 01:46 PM
monster7's Avatar
high volume pumps with stock pans are not the best idea. under hard driving you can drain the pain dry. unless you use a light weight oil
00Z-28-LT1's Avatar
i have the high volume high pressure in a 7 quart pan though, get the melling engin saver when you do this
Old Jul 12, 2005 | 06:42 PM
96capricemgr's Avatar
The LT1s oiling system is pretty good, a high volume pump will just sap a little more power and as mentioned could suck the pan dry under sustained high rpm usage.
Old Jul 13, 2005 | 12:18 PM
If you look up the stock LT1 pump gm refers to it as "high volume"
Old Jul 13, 2005 | 05:05 PM
BigKap94z's Avatar
I don't think there is any need for a high volume pump with a stock oil pan. STD volume pumps are plenty, even for a built engine. Besides oil system capacity I believe another determining factor would be how the bearing clearances are set. I know a few engine builders that run almost all std volume pumps, and change the spring to raise oil pressure.
