Fan Switch Mod
Old Sep 1, 2005 | 04:31 PM
StreetKing's Avatar
Default Fan Switch Mod
How do I do the manual fan switch mod. Any websites show how to do it?
Old Sep 1, 2005 | 04:44 PM
transamtom's Avatar
Go here:
http://www.fbody.com/tech/details.cgi?id=14
Old Sep 1, 2005 | 10:36 PM
State69champ's Avatar
oh this is simple
I did it a couple days ago.
-Take out your pcm and find "RED"
-Find wire # 10
-splice into it.
-Run a wire to your switch
-Run a good ground to your switch
-turn on ignition
-hit the switch
Enjoy.
Its really that simple Ill send you pics of my set up if you want.
Old Sep 1, 2005 | 10:38 PM
You can also slice into wire #11 10 is the right fan 11 is left.
Old Sep 4, 2005 | 02:10 PM
This would be a good FAQ
Old Sep 7, 2005 | 09:41 PM
97Z28LT1's Avatar
What would you do to run both of the fans?
Would it be safe to run both wires (10 and 11) on the same switch?
Would it really be that much more beneficial to run both fans?
Old Sep 7, 2005 | 09:53 PM
I was actually thinking the same.... I guess you could try and hook both hot wires up... dont see that hurting anything.
I could be wrong.
Old Sep 8, 2005 | 11:44 AM
01WS6/tamu's Avatar
Those same wires are also located in a weather pack connector on top of the passenger side wheelhouse where they connect to the forward lighting harness and run to the relay box.
Old Sep 8, 2005 | 08:12 PM
urbanhunter44's Avatar
I followed the instructions on fbody.com, except I routed my hot wire all the way through my amp/subs power line up to the battery.
I'd highly recommend an LED light with this as well, as it seems easy to leave it on when you get out of the car ask me how I know!
Old Sep 11, 2005 | 06:11 PM
CJDZ24_Z28's Avatar
IM really big on doing free mods or mods that cost little money. I looked into this and i just figured ill drive up to SLP and got their fan switch installed it in about 30 min. Good Luck!
