Best Modifications for the money?
Note: I wil be putting about $1000 into suspension work.
You can easily spend $1000 in suspension/chassis. If you dont already have, subframe connectors, lowering springs, and shocks will set you pretty close to the $1000.
((((( from Bad-*** Racing Engines)))))
Q: Do I really need forged rods and forged pistons?
That's a BIG question, and it depends on what you are running and how you treat (or abuse) your engine. Let's start with the rods first. First of all, ALL rods are made out of forged steel. They certainly aren't made out of cast iron, or they'd simply be too brittle and would snap in half. With that, most factory rods are fairly strong. In the older days, we used to polish the beams of factory rods to get rid of "stress risers", and install stronger SPS rod bolts and run them in 500HP race engines.
