Oil sending unit location?
I had my cutout installed today and the welder told me that I was leaking oil from somewhere high on the engine,and he asked me if my oil pressure fluxuated much,well it does and he suggested I look into replacing the oil sending unit.Where is it?How much do they run?How hard is it to replace?Do I need to have the car up in the air to replace it or can I get to it from the top?thanks
It's straight back behind the valve cover on the driver side. It's about 2 inches long and sticks straight up in the air. It's easy broken. I've never tried changing it in the car, I replaced mine while I had the engine out anyway. It's a booger. It's tight in there and with limited space, I would say it would be difficult. There's no way to get it from the bottom. Good luck.
Originally Posted by SmokedOutZ28
Are you sure it's not a intake leak? They tend to leak over time.
i have the same problem while im driving the pressure stays up but when i get on the brakes to stop my oil pressure drops all the way off and my check gauges light comes on but after i sit for a second the pressure comes back up and the light goes back off nothing serious but very irritating and i would like to know how to fix it ill take it to a shop if i have to but i think i might be able to do it just did a 6 speed swap into my bird so it cant be to much worse than that i hope
Not every year had it located at the top of the eng. Some are located on the drivers side of the block down by the filter. Just take a flash light and a mirror and look for the leak.
How difficult is it to change with the motor in the car?Anyone do this?
