Biggest cam on LT1?
Good luck finding info, If the thread isnt about a catback exhaust and sound you dont get a reply.......Im in the same boat and would like to know also..
i have 600 lift, and when i have plenty of piston to valve clearence. my heads have been milled.
just dont exspect to go fast if all your wanting to do is throw the biggest cam in... probably wont gain much if anything over the 305 going bigger unless you get heads.
Well you didnt answer this guys qeustion, he is asking biggest cam best power gains and somthing that is going to work. I would like to know also whats the biggest cam that will make power or best cam thats worth upgrading to.
Not just whats the biggest cam ever Yo"
I agree cam/heads/intake are the key boltons for "reasonable" priced power but he's asking about cams.
and thats pretty common for the hot cam and similar.
), I upgraded a couple weeks later with 1.7 Comp ProMag Stainless RRs with better springs, CompRs, 1pc pushrods, guides and PCM tuning, this got me to around 350-355 with the better valvetrain components. im running an fms cam. 233/241 573/597. you can get away with quite a bit of lift since our pistons are in the cyclinders a little ways.
if he wants to make power he should look into a custom cam. the "off the shelf" cams will only take you so far.
Wow that seem like a lot for just bolt ons. What specifically did you have?
MeanGreen your may try some research on camaroz28.com as well if you haven't already, quite a bit of info on several cams on stock heads of this spec.
