Are these any good.
Old 07-18-2006, 03:30 PM
95 Camaro Z28's Avatar
Default Are these any good.
doing h/c and i was told bolts can only be torqued correctly once, so would these be a good replacement for a mild motor? only mods are mid tube headers, borla catback, k&n, and lt4 hotcam, 1.6rr, dual spring p&p heads.
http://cgi.ebay.com/ebaymotors/SB-Ch...spagenameZWDVW
Old 07-18-2006, 04:07 PM
aggiez28's Avatar
never heard of them, ive allways just used ARP
Old 07-18-2006, 04:48 PM
camar0corey's Avatar
You might as well upgrade, but the head bolts on the LT motors can be reused.
Old 07-18-2006, 05:19 PM
id much rather reuse them if i can. but someone on another forum said they can only be used 1 times, prolly due to strectching.
i like arp as well but 60$ for some bolts is steep.
Old 07-18-2006, 05:36 PM
MEAN LT1's Avatar
Im pretty sure the stock head bolts are torque to yeild and cannot be reused once they have been untorqued. Get some ARP's
Old 07-18-2006, 08:53 PM
MrBill97396's Avatar
Stock GM head bolts are torque to yield, but are cheap to buy new ones. Keep the old ones for mock up though.
Old 07-18-2006, 09:18 PM
James Montigny's Avatar
I'd go with ARP, they're not that much more expensive and they have a solid reputation.
Head bolts are not something you want to cut corners on.
Old 07-18-2006, 09:19 PM
burnzilla's Avatar
If youre in there, you might as well eliminate the possibility.
Even after inspection they turn out to be ok, I would get new ones anyways.
Old 07-19-2006, 03:42 AM
teamguru69's Avatar
i have arp and they work great
Old 07-19-2006, 11:10 AM
the_merv's Avatar
I have to remove my Heads to change the Head Gaskets, so you guys reccommend new bolts..
Old 07-19-2006, 12:25 PM
Yes, it is the safest and correct way to do it. Plus the security of knowing you will not have bolt tension failure.
Old 07-19-2006, 12:48 PM
I agree, it's cheap insurance.
Clean parts, new gaskets and fresh bolts are always a good idea.
You'd be taking a risk reusing stock bolts.
Old 07-19-2006, 12:54 PM
Honda Hunter's Avatar
Exactly. ARP's are reusable I believe.
Old 07-19-2006, 01:15 PM
the_merv's Avatar
Anyone have a part # for the GM Head Bolts?
Old 07-19-2006, 02:21 PM
daniel6718's Avatar
ive reused mine 2 times...and i pull my car to 7000 frequently...dont see a problem...whe ni hit the 125 and po a head gasket ill get some arp
Old 07-19-2006, 03:08 PM
the_merv's Avatar
You are talking about the Factory ones... I only do street driving, and maybe a little screwin around..
Old 07-19-2006, 03:10 PM
Torque to yield head bolts
Torque to yield (TTY) bolts, also commonly referred to as angle torque or stretch bolts, are used in many of today's modern engines predominantly for cylinder head bolts but also main bearing and big end caps.
Compared to conventional type bolts, TTY bolts offer the engine manufacturer a number of advantages including greater flexibility of design, reductions in component costs, more accurate assembly and reliability of seal. Engines designed utilising TTY head bolts require fewer head bolts to achieve the desired clamping loads then those using conventional bolts. With fewer bolts the engine manufacturer has more flexibility in cylinder head and block design as well as reducing the cost of the engine.
Whilst TTY bolts are attractive to the engine manufacturer, there are disadvantages to the engine repairer. For the most of us it would be unthinkable to replace a conventional head bolt unless the bolt was damaged, i.e. stripped threads, the bolt head was rounded off, the shank was severely corroded or pitted.
Conventional head bolts simply just did not wear out. Torque to yield head bolts however, by the very nature of their design, do wear out and should NEVER be reused.
Old 07-19-2006, 03:40 PM
NAL-12495499 in summit The Merv.
And to reuse your old head bolts multiple time is kinda like reusing a loaded condom. It wil work but it really is not the way it should be done because it is dirty and worn out.
Old 07-19-2006, 04:29 PM
