Different Intake Question. LT1 big dogs come in.
Ok. When I go to build my lt1 into the beast that is really was meant to be, im not staying lt1. I dont see reason.
What I want to do is basicly stick all the lt1 injection and such on a SBC. This way I can use SBC heads and have all the benifits of the large aftermarket. So what does this take? Or how about this.... How cheaply can I jsut take a normal SBC intake, convert it to EFI as CHEAP as possible?
If at all possible I would like retain the LT1 pcm if at all possible also (alternatives are $$$... im on a budget.. kinda... lol). And are the motor mounts different on the SBC? Only reason I ask is the aftermarket offers a SBC crossmember.
In essence I would like to put a SBC in... but with EFI. If it is cheaper and easier to convert the LT1 intake I will. If not, I will jsut use a standard single plane. If there is NO WAY AT ALL TO USE THE LT1 PCM EASILY i will just megasquirt it.
Thanks for input. If anyone has some productive suggestions please go to town. I want to hear anything.
EDIT: I will attempt to go Megasquirt or something of the like either way. It is a boosted LT1 and the stock PCM blows complete nuts for boost in the first place. Any area I can cut cost im going to try to.
Originally Posted by GIZMO
I would ditch the factory computer long before I would ditch the LT1!
But im somewhat ditching the lt1 because its gunna go this comming season (8-10lbs of boost and some nitrous tends to do that to stock lt1s...)
But anyhting you got to help me out on this would be great.
ahhh huh??? so u want to re-invent the wheel but keep it on a budget.... sorry bro dont know y u would want to go that route unless u are trying to build a 8 second car. u can easily be in the 9's on some nitrous with a LT1 so either get ready for a simple headache or head bashing project. Either way u will proably spend the same amount of money. Trust me I have done quite a few LT1's and LS1's to know that it all costs money.
Humm.. my post isn't showing up though it says i already posted it... wtf
here it is again...
True. Its gunna be a headache. But Im not reinventing the wheel.
When it comes down to the basics... Im jsut fuel injecting a SBC (that has some nice brodix heads or something on it), putting a turbo on it (the one off the lt1) and putting it in a nice home (my LT1 TA)
That is all im doing. The closest to reinventing anyhting is putting the LT1 intake on the SBC (if I choose to do so) and this has been done 100 times over within the 3rd gen crowd.
I really think it can be done for a fair price (i know how these things go guys.. lol.. the turbo kit was a fun project .. and still is... $$$ ****... ). I know it is going to cost more than i will anticipate. But that is not a problem. I just need a little help in my research
here it is again...
We custom made our intakes but that does not seem to be the whole question
I have a MS sitting here but for now I am just making all the power I can under the 7,200 curve It will be easier for you to use the MS because you are already missing the opti. You WILL need to retain the PCM if you want the factory dash to work. Just do the piggy back
BTW using a LT1 intake or heads on a Gen I is nothing new. they have been doing that since they hit the streets in 92
BTW using a LT1 intak or heads on a Gen I is nothing new. they have been doing that since they hit the streets in 92
I dont want to use the LT1 heads... that is the biggest reason for goign to SBC... one... blocks are a dime a dozen... and there is a MASSIVE aftermarket when it comes to heads...
So any help... please please let me in on some tips
Guest
Posts: n/a
http://store.summitracing.com/partde...5&autoview=sku
there is no need to have a carb intake converted to EFI
That's MISTER MODERATOR
That's an idea, to convert back to a SB1. To use the LT1 PCM (to save the trouble and cost of pulling out the old system and installing a new one, I presume) you'll need to get the optispark distributer to somehow work. The timing covers are completely different. The LT1 PCM will not work with any other kind of distributer that I've even heard of. If there was, we'd all have converted to it.
thats the only downside considering IM trying to make a turbo car that i will shift at in the mid 6000's (why should I have to spin it anymore than that? I would even like to do less... RPM kills motors)
And I want it to have some grunt as low as 3500 at least...
Not that it matters that much really...
Well Im thinking megasquirt is goign to be the best bet.
Its not even going to be a LT1 at all when im done, but I can say it is (not THAT big a difference)
But what recomendatiosn would you all make... lol... I love the comments but somethign to help would be great.
I probly can handle making a SBC EFI and bolting the turbo setup off the lt1 on it. What do I need to make it fit though? And without cutting the **** out of my car...
EDIT: "recomendatiosn"??? jesus was a drunk when i typed that...recommendations
Edelbrock has a complete E series of carb style manifolds. You just listed a single plane and I linked to the one I am going to use on my LT1
Guest
Posts: n/a
A buddy of mine is trying to do that with his Turbo Supra..... The motor just got pulled again, for the third time in over a month......
Don't cut corners, save your money and do it right the first time....
My car ran like crap this summer (well ran strong compared to like a raped ape). I saved my money and am fixing it the right was this winter...
Just doing a SBC. Full forged bottom end (Callies/Compstar probly). basicly any heads and what not that i want. Edelbrock EFI intake and fuel rails. Then whatever I can do to keep stock fuel lines (why not... they support whatever i need). Run megasquirt. Use my turbo setup off the lt1.
And it sounds like im going to need the SBC crossmember to mount the motor.
And Im goign to need to cut the cowl the make room for the throttlebody and what not also huh?
Thanks for any help and advice anyone has/is giving.
From what I can tell you want Id go braided (larger) fuel line.... can't go cheap or to safe on fuel stuff..... or engine goes BOOM!!!!!!!!!!!!! in a very bad way...
You know how fast either of them are? Well Mike trapped 143 with his turbo lt1.
You all know who Ellis is so im not going to waste my time talking about him...
Both of them crazy ****'s are running STOCK FUEL LINES AND REGULATER!!!! They have plenty of fuel to spare. People missinterpret fuel starvation as problems with the stock lines... these two are running this fast and not a single problem...
So why should i change them again?
lol.. sorry.. not trying to be a ***.. this is just a subject people are mislead on
Drag. Go with the intake that fits the best and flows alot. a Turbo will put the ait through what ever you have regaurdless of advetised RPM Range. I am using a Holly Stealth Ram for my TT 79 Step side
Also get a good Meth kit to go with your new system.
I know how to make the Opti work on a Gen I but would not bother for a boosted engine. It is good to see someone had been listening all this time while I was preaching about the LT1 PCM and boost
Depending on how efficent the engine is stock fuel lines and Meth should be fine. I think I maybe nearing the limit of the lines but I am not sure yet You Must remember a N/A-N2O engine uses it's fuel most efficently then a Boost engine. Meth will help cover that to a point
BMR makes a nice Gen I K member
Good luck man!
BTW I am still using modified stock LT1 heads. . .The set that came on the car when it was new
Good luck man!
9-Second Club
You don't need bigger fuel lines, or different regulators. I've even sprayed mine with stock pump, lines and regulator. If you only want to go nines, you don't need anything else. The computer will make more difference than an intake manifold. My buddy Rick Abare recently went to a Holley Comander 950 ECU, and this past weekend went:
9.99 @ 138.211 , 1.32 60' at 347' DA
9.98 @ 138.088, 1.44 60' at 469' DA
9.98 @ 138.715, 1.42 60' at 382 DA
9.97 @ 138.749, 1.42 60' at 120' DA
This is normally aspirated with LT1 heads and intake (not even LT4) and a 4L60E which is still using the factory PCM. This is the car on AI's website.
Last week I went ahead and ordered a FAST XFI system for mine. I'll try to get time to install and tune it before Englishtown.
9-Second Club
