Fuel Pressure Regulator
Old Oct 24, 2006 | 04:16 PM
LT1_King's Avatar
Default Fuel Pressure Regulator
my car idles pretty rough and when i get on it to about 3500-4000 rpms it starts throwing out black smoke through the exhaust. could this be a lack of fuel maybe it could be running lean? could this be the fule pressure regulator or if i changed the fuel filter could that help? it's a 94Z A4.
Old Oct 24, 2006 | 04:42 PM
slohatch91's Avatar
black smoke mean too rich. too much fuel pressure. do you have a fuel pres. guage?
Old Oct 24, 2006 | 04:46 PM
Revelation Z28's Avatar
check your o2 sensors.
Old Oct 24, 2006 | 05:33 PM
Matts94Z28's Avatar
check o2's first...i had the same issue before i changed mine
Old Oct 24, 2006 | 05:45 PM
seawolf06's Avatar
and plugs...
Old Oct 25, 2006 | 08:46 AM
LT1_King's Avatar
the plugs are new. i went with a friend to a Chevrolet House. we hooked up the Guage and at idle it read about 35 PSI. when he would give it gas the pressure would drop to about 20-25 PSI. would this mean the regulator is messed up or could i start by changing the fuel filter maybe it is just clogged.
Old Oct 25, 2006 | 08:52 AM
Boodyrider's Avatar
Start with fuel filter. 12 bucks at most auto parts stores.
Old Oct 25, 2006 | 08:55 AM
Boodyrider's Avatar
Idle pressure, don't forget engine vaccuum is subtracted from static pressure. IE. 16 inches vac is about 8 psi, and static pressure is 43 psi, so you'd see around 35 psi at idle if you didn't disconnect the vac reference from the fpr.
No, you DONT need a new fpr, it sounds like it's doing exactly what it is supposed to.
