m6 guys, what do you shift at?
Some people are hell bent on shifting stock H&C LT1's at 6000 RPM. All things being equal you would smoke the other guy shifting to high.
Dont get a shift light for a stock ride (just looks like rice).... It should be pretty obvoius to feel where the powerband stops just from driving the car all the time. I mean, if you just goto the track once and make 10-15 passes, you should be able to tune your senses to hear and feel it assuming your used to driving a manual all the time.
My car has CAI, Chip and Magnaflow cat-back (installed before purchase of car) and I shift at 5500 or so... So I should be shifting 300-400rpm higher? At what rpm does flat float occur?
even tho at 6000 the cam has quit making its power, when you shift up a gear at 6000rpm, that will put you 200-300 rpms higher in the next gear and those extra rpms supposedly make up for the over reving in the previous gear. just my .02. oh yea the stock rev limiter is at 6200 if that means anything to you.
I moved mine out to the way through PCM tuning and use my MSD box to soft touch the rpm at 6300. I agree with shifting the motor at 200 to 300 above what you think so it will back into the phat of the cam on the gear change. I'm usually around 61/6200 1st gear to 2nd and all other gears after 60/6100 depending on how it feels. I have squeezed a 12.61 @ 109 shifting this way. baby it
haul *** After today I have decided the CF dual friction clutch isn't too happy with 2-3 and 3-4 powershifts, didn't seem to get any quicker. Actually got slower.
I'm curious as to what people launch at on street tires, I can't seem to launch worth a damn.
