LS1 driveshaft advantages?
Old Nov 14, 2006 | 09:40 AM
maybe2fast's Avatar
Default LS1 driveshaft advantages?
I know afew of the advantages, but can you guys that have done it share there thoughts on the swap?
I am thinking about doing it, but don't want to waste my money.
Old Nov 14, 2006 | 10:29 AM
streetwarrior96's Avatar
on an M6 they are good for full bolt on power . Once you start getting H/C, strokers settups. Get something better. Mine did'nt last 2 runs down the track
http://www.dennysdriveshaft.com/html/nitrous_ready.html
Old Nov 14, 2006 | 10:31 AM
dhdenney's Avatar
Yeah I know a guy that busted his first time out with his H/C combo. Stock car, DD--good mod. Other than that, you can do better.
Old Nov 14, 2006 | 10:32 AM
BlackScreaminMachine's Avatar
Internet Mechanic
A friend with a 93 t/a swapped in a peice, didnt see a gain at the dyno, nor the track but it was better balanced then the stocker. The dyno can very 1-5 hp between runs so that could have been the gain of the DS. It couldnt hurt since the u-joints are newer.
Old Nov 14, 2006 | 10:36 AM
Oh I also did the 1350 yolk conversion on my 7.5. I also broke that. You can get that from Randy's Ring and Pinion.
Old Nov 14, 2006 | 11:36 AM
LT1MAN's Avatar
i swapped the ls1 shaft onto my car, but since i am going 383 should i put my steel shaft back in?
Old Nov 14, 2006 | 12:07 PM
dhdenney's Avatar
Yeah you're gonna break that. I would buy a Speed Inc steel shaft or a Denny's custom shaft cuz with M6, you're just asking for trouble. I broke a 3.5" Lingenfelter aluminum shaft with an automatic.
Old Nov 14, 2006 | 12:52 PM
rasputin's Avatar
what is the average gain from an aluminum driveshaft? 1-3rwhp/5rwtq?
Old Nov 14, 2006 | 01:10 PM
JUICED96Z
Guest
Posts: n/a
Would it be ok on a full bolt-on car with a 3200 stall and stickies spraying a 150 off the line? Stock H/C.
Old Nov 14, 2006 | 02:05 PM
maybe2fast's Avatar
I was going to do the hot cam and rocker setup with bolt ons. I guess I should stick with the steel one for now. I just found a good deal so I was wondering if it was worth it.
Old Nov 14, 2006 | 02:25 PM
Formula350's Avatar
I like good deals
Old Nov 14, 2006 | 02:37 PM
camar0corey's Avatar
I did the swap, it seemed to weigh alot less. Did I notice a performance difference? Not a fair question in my case as I installed the spohn torque arm the same night. I don't think I ever had that shake with my steel one, so I don't know.
How much is a good deal? I spent $100 for mine off ebay.
Old Nov 14, 2006 | 02:42 PM
Camaroholic's Avatar
I got mine for free. Worth it to me.
(I put a Denny's NR in my 98Z, so I put the 98Z Al shaft in the 94Z)
Would I actually buy one? No, not a stock Al shaft. Money's better spent on something beefier. My Denny's is heavy, but it's one thing I don't worry about breaking with a 6400 RPM launch spraying out of the hole
Old Nov 14, 2006 | 02:56 PM
Internet Mechanic
I can contest, the n2o ready DS is heavy, but with my new LS1, when the Moser goes in, as long as the slip travel is correct I will put that in and just keep the Al ds incase I swap back.
Old Nov 14, 2006 | 03:02 PM
maybe2fast's Avatar
so for my cam valve train work plus bolt ons...just stick with what I got?
75 for the shaft...used
Old Nov 14, 2006 | 05:37 PM
rasputin's Avatar
thats the kinda situation I was in, 60 bucks for a used LS1 DS....why not? I spend that on drinks every thursday night, mine as well sacrifice a night of fun for a few ponies. as I learned in my aerospace class many moons ago, parasitic drag kills power, its only logical it would add a few horsepower.
Old Nov 14, 2006 | 07:01 PM
maybe2fast's Avatar
but it may break
Old Nov 14, 2006 | 07:11 PM
Formula350's Avatar
We dont make what LS1's make, so I doubt it'll break. Unless you're launching.
Old Nov 14, 2006 | 07:35 PM
Ls1Bait's Avatar
Yea mines no where neer a LS1s Power
Old Nov 14, 2006 | 08:17 PM
I heard the ls1 shaft was stronger and lighter, the ls1 cars made more power and then GM put a aluminum shaft on vehicles that made more power mod for mod. I don't think its going to just break on you. For $75 you probably can't go wrong.
