Car Shakes?
Old 12-05-2006, 06:15 PM
626KLZE's Avatar
Default Car Shakes?
Everytime I let off the gas at a high RPM my car shakes badly, it's a vibration
that just feels bad! I was think U Joints, but please inform me on this. Thanks
1997 Chevrolet Camaro Z28 MT
Old 12-05-2006, 09:07 PM
Revelation Z28's Avatar
your LT1 wants to keep going!!
Old 12-06-2006, 12:06 PM
TAEnvy's Avatar
Mine does the same, but at low RPMS.
Old 12-06-2006, 12:22 PM
1FstFormulaV8's Avatar
Are you just letting off the gas? Leaving the clutch engaged?
Old 12-06-2006, 08:51 PM
626KLZE's Avatar
Yeah just letting off the gas, I mean the vibration isn't extreme, it's just annoying.
Old 12-07-2006, 07:22 AM
the_merv's Avatar
Probably the Drive Shaft.. I got a LS1 Aluminum one, and haven't had a problem. It will hit 130+ and be smooth the whole way.
Old 12-07-2006, 12:58 PM
TAEnvy's Avatar
I need one of dem dare fancy pancy aruminlum Drive shafts.
Old 12-07-2006, 02:10 PM
the_merv's Avatar
I got it for $50...cheap fancy there..
Old 12-07-2006, 04:14 PM
-PEPE-'s Avatar
dude that **** was funny...the aluminum ds wouldn't last the burnout box on mine...
626KLZE - You might also check you're front rotors, my old setup was doing the same identical thing and everything else was fine, just the front rotors were shot, new rotors and smooth as butter.
Old 12-07-2006, 04:22 PM
hashtagBMW
Speed Density's Avatar
I think thats what most LT1'ers dont understand. Its probly good for a Bolton car to go All. DS, but when you make a larger amount of power the DS becomes a bunch of peices.
Tony.
Old 12-07-2006, 05:17 PM
WhyHelloOfficer's Avatar
I'll agree with that one. Runout in your rotors can definately cause a vibration. Also the driveshaft if its the factory steel one can vibrate too.
You might also want to take a look at the transmission mount. If it is a new poly one, it could not be installed correctly can be causing the vibration. I know that mine vibrated at highway speeds when I let off the gas. If its old, look into getting a new one -- and make sure you install it correctly.
Old 12-07-2006, 05:53 PM
Moderator
BizZzatch350's Avatar
The GM 1LE is suppose to be a better unit than the stock LS1 d.s, if you had a factory warranty thats actually what they replaced the stock steel one but this was like in 01ish when the last 96-97 cars were running out of their extended warranty points. So I think its safe to safe to no one on here has any sort of warranty left.
Old 12-07-2006, 05:59 PM
the_merv's Avatar
I am not complaining about the LS1 one, it works very well for my setup. Got it cheap and it works.
Quick Reply: Car Shakes?
