anyone using valve cover adapters?
The only option really is some custom fabricated ones, or Canton makes a pretty nice piece as well.
Wow, I've definitely been out of the picture on these things. Does summit sell them? Trending Topics
Part # TFS-31500811
They are pretty expensive
but it is nice to have a huge selection of the perimeter bolton valvecovers. The Best V8 Stories One Small Block at Time
"This is an adapter that allows centerbolt heads to use perimeter bolt valve covers. Narrow body rocker arms are required to clear the adapter."
Might be a problem, might not...
Alot of those adapters put the o-ring on the perimeter and set it into a square rabbet joint. The problem is that half the rail still makes metal to metal contact with the top of the rocker wall, and doesn't allow for adequate clamping pressure on the o-ring for it to seal tightly enough. The above pictured ones place the o-ring at dead center of the rail which puts all the clamping force directly onto it, preventing seepage. Those adapters also don't require narrow body rockers like the Trickflows do.
http://www.jegs.com/webapp/wcs/store...0002_757463_-1
I clearanced mine, I have the Trick Flow ones. They leaked, got it fixed but the ones that thesoundandfury posted are a lot nicer.
