anybody running TEA 220CC CNC PORTED lt1
Old 03-25-2007, 03:07 PM
travie319's Avatar
Default anybody running TEA 220CC CNC PORTED lt1
just wondering if anyone is running these.....and how are they performing...
(dyno#'s, track times, etc...)
Old 03-25-2007, 03:11 PM
1bdbrd's Avatar
do you have any links to these heads? i dont see them listed on their website?
Old 03-25-2007, 03:23 PM
raymond mckinney's Avatar
I've never heard of or seen these.
Old 03-25-2007, 06:04 PM
travie319's Avatar
http://www.totalengineairflow.com/pr...gmhead/tfslt1/
scroll to bottom!
Old 03-25-2007, 06:35 PM
speed_demon24's Avatar
I wonder what they flow on a 4.03" bore.
Old 03-25-2007, 07:24 PM
96silverram's Avatar
Wow, those flow real well @ .600 (314)
Old 03-25-2007, 08:32 PM
96capricemgr's Avatar
What would that have to do with anything?
Good to see other individuals cutting through the marketing .
Vendors do not need to lie to mislead folks, most people just skim past those all important notes and in doing so miss details that endup having them comparing apples and oranges without realizing it.
Old 03-26-2007, 12:55 PM
Turbo_6's Avatar
Why it is not an industry standard to flow heads on a 4.000" bore is beyond me. So many of us have aftermarket DART blocks and all with those big 4.125" bores.
Old 03-27-2007, 07:56 PM
travie319's Avatar
ttt for anybody that might help......
Old 03-27-2007, 08:36 PM
FASTFATBOY's Avatar
You guys KNOW they flowed them on a 4.030
Truth known it was a 4.155 bore and every trick in the book, how the hell do you get a stock casting to 220 cc?
David
Old 03-27-2007, 08:37 PM
lt1taracing's Avatar
impressive #'s. thats a trickflow head thats been poerted by TEA, correct???????
Old 03-27-2007, 08:46 PM
FASTFATBOY's Avatar
Yeh I just looked at it, flowed on a 4.125 bore, Trickflow 220 CNC port.
David
Old 03-27-2007, 09:35 PM
Most places use a 4.030 because that is a VERY common bore on the performance motors worked heads endup on.
Some places like to use a 4.060 to fluff the numbers a little.
Honestly my best guess on this case after some thought is that those are actually the flow numbers from the gen 1 version of this head hence the big bore. Have to figure the gen 1 smallblock was available as a 400ci motor which I am fairly sure was a 4.125 bore stock.
Still wrong to post those numbers for that bore on an LT1 head but is an explaination that stops short of flat out deception.
Old 03-28-2007, 09:11 AM
1997bird's Avatar
They may have been trying to market the heads for the larger cube LT1's. AFR tests their 210, 220, & 227's on a 4.125" bore, so they may have left the same bore fixture size for a compairison between the heads. It's not practical for a LT1 bore size, unless you have your block sleeved.
And yes the older SBC 400 had a 4.125" bore with a 3.75" stroke.
Old 07-12-2008, 04:35 PM
flyinZ's Avatar
Has anybody heard/read anything new about these heads?
Old 07-14-2008, 02:57 AM
travie319's Avatar
holy back from the dead thread...lol
Quick Reply: anybody running TEA 220CC CNC PORTED lt1
