Best Cut-Out?
But I suggest going stainless. Whatever brand you choose that's up to you, but stainless steel is the way to go. I just purchased a QTP stainless cutout myself.
On the dyno, it showed a peak of 13rwtq and averaged about 9 rwtq more with the cutout open across the entire run without losing any low-end torque.
Without cats, I don't know if it would make much of a difference but you wouldn't lose bottom end. It would probably be too loud under the car to have it open when cruising.
One of the engine dyno tests carried out by Kevin was on warm 351 4V Cleveland V8. Following the extractors, he fitted a huge exhaust that gave a measured zero back-pressure. Torque peaked at 423 ft-lb at 4700 rpm, with power a rousing 441hp at 6300 rpm. He then dialled-in 1.5 psi back-pressure. Note that very few exhausts are capable of delivering such a low back-pressure on a road car. Even with this small amount of back-pressure, peak torque dropped by 4 per cent and peak power by 5 per cent. He then changed the butterfly position to give 2.5 psi back-pressure. Torque and power decreased again, both dropping by 7 per cent over having zero back-pressure!"
I gained about 9rwtq and 4rwhp with them open VS closed.
But only 3rwtq over what I had without cutouts.
(Translation: Closed cutouts made less power than no cutouts)
The gains were minimal over the 3" hooker muffler, I just took it off alltogether.
Now if your going to go with a ecutout then DMH is the way to go.Also your not going to notice any real gains from a cutout like I mentioned earlier. Especially if you just goof around on the street. You will loose some back pressure which will cause you to loose some bottom end power (launching).
With a cutout you'll gain a few horsepower but loose some torque, torque is what you feel, what pulls the car.
now we're on the same page. For the price buy a stainless manual cutout. 3inch. If you feel compelled to buy a electric motor for it later on you always can. I think the ecutout is useless imo. I never run the cutout open around town only at car shows and at the track, so there's no point blowing 200 bux for something that won't be used.
On a good free-flowing exhaust system a cutout won't do much as I think you've seen.(3rwtq wouldn't be worth putting in a cutout for performance and could be dyno variation)
On mine, I have to run cats so I wanted the cutouts ahead of them which means right after the headers.
Backpressure isn't needed on a properly tuned engine. Exhaust scavenging is which is why you don't want to put a cutout too far up the system.
-and-
You will not lose tq anywhere in the rpm range assuming the car is tuned properly.
I have been saying this for years now and everyone just says no, cars need backpressure. Would sure to kindly inform them of some tests in the area.
