Any test results for the Edelbrock intake yet?
Originally Posted by Formula350
Some have bought it, but most of us don't want to be LS1Tech's guinea pigs lol I would if I had the money.
Soon as I get around to dynoing the car, I'll be happy to post the results. The only thing I changed was the manifold itself. I wasn't looking for a real power improvement but I had the rear intake manifold leak that I swear was due to the stock intake not being "true". The stocker has been off the car 3 times and installed by 3 different people which doesn't quite add up. Next dyno day in my area and I'll throw it on and see what happens.
-Brian
-Brian
Originally Posted by Blackbirdws6
....but I had the rear intake manifold leak that I swear was due to the stock intake not being "true". The stocker has been off the car 3 times and installed by 3 different people which doesn't quite add up...
-Brian
-Brian
I wanted to fix it over the winter, while the car was in storage, but the Permatex Product Tech that I spoke with said that the ambient temp in the garage needed to be at LEAST 45-50 for the RTV to cure. That didn't happen until 2-3 weeks ago, and I wanted to drive the car a little, but I despise fluid leaks.
I ordered a gasket set today, maybe I'll fix it the weekend after next...The prediction for here is SNOW AGAIN, for Easter!
I was just getting used to 50's
SNOW !!!!
I haven't even checked behind my intake yet I might have to. Mine looks like it's been off before, but I don't know when since I only got the car 1000 miles ago, there abouts.
if weather is good this weekend, taking it to a dyno day and will post results. Only trouble is it may not tell much since its at a different dyno than the car was first dyno'd. Supposedly the dyno I am going to is +/-5% of a dynojet. Results to come.
-brian
-brian
from the looks of the manifold, i cant see how it gains a whole lot, but heh, who ever looked at a set of heads from the outside and guessed how much they flowed?
It's the only "significant" mod I've done. I bought this because I think my stock manifold is not true or is warped in some manor. I've had the rear intake leak replaced 3 times. Twice to fix just that issue and once during the heads/cam swap and it was still doing it. Hopefully I'll pick up a few ponies for fixing this issue. Oil pressure is much much higher now without the leak which is nice. It was never low enough for concern but it should be a bit higher. Again, these will prob not come out to be perfect condition results but I haven't seen any others so maybe it will be useful.
-brian
-brian
