Taking some weight out of EPPs LT1 project car
Old Jan 31, 2008 | 09:35 PM
  #41
1SlowFormula's Avatar
thanks for weighing it all, I have a few of these to still do, glad to know what to expect...
Old Feb 2, 2008 | 06:18 AM
  #42
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Originally Posted by Dragframe
Love the car. Interested to see how far you can push the stock engine.
Thanks, if we can get it in the 10s without having to pull the intake...we may just throw a cam and heads on it to see what it will do with stock bottom end.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Feb 2, 2008 | 06:21 AM
  #43
LS1TECH Sponsor
I'll be doing some of the interior....steering wheel, seats, etc. I still want to be able to drive to town and back so the heat and stereo will stay in. I'll keep you posted on the rest we pull out.
__________________
Old Feb 11, 2008 | 07:00 PM
  #44
LS1TECH Sponsor
Replaced BMR K-member with one for manual rack= +1.72 lbs.
ATI Balancer vs stock= +1.8 lbs.
Power steering system w/fluid= 32.3 lbs.
New flaming river manual rack set up= 15.73 lbs.
total savings in manual= -16.57
A/C compressor= -15.37 lbs.
A/C bracket and idler pulley= -8.00
Accumulator and lines= -4.3 lbs.
Condensor= -8.21 lbs.
Washer bottle= -1.69 lbs. -8.23 lbs. when full (It was full when in car)
Crash bar= -16.53 lbs.
Front foam support w/clips= -3.28 lbs.
ABS unit= -12.44 lbs.
Cruise control= -3.01 lbs.
Brake booster= -9.73 lbs.
Replaced single adjustable QA1 struts with double adjustable QA1= +.29 lbs.
Replaced 315 lb. QA1 springs with 300 lb. QA1 springs= +3.76 lbs.
Strange front brakes= -40.9 lbs.
Cut LH spindle= -3.83 lbs.
Cut RH spindle= -3.69 lbs.
Strange master cylinder vs stock= +1.97 lbs.
Old rear brakes= 23.10 lbs. each
Wilwood race brakes= 11.37 lbs. each
Total savings in rear brakes= -23.46 lbs.
Old intercooler tubing from 2nd intercooler up= 16.02 lbs.
New style procharger tubing in aluminum= 8.31 lbs.
Total savings in intercooler set up= -7.71 lbs.
Total reduction so far= -175.72 lbs.
Anyone with the old Procharger intercooler piping that has two pipes coming up from the bottom going into one knows how heavy it is. We went with Procharger's new design and by changing some of the pipes to aluminum got almost 8 lbs. out of her. I will have the pics loaded soon and would like to thank Brent for doing some welding on the aluminum pipes.
Jon
__________________
Old Feb 11, 2008 | 10:13 PM
  #45
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I wish I knew what mine weighed to start with. I'm trying to do the same thing now, but I'm not going as extreme.
So far all I've got weighed is the front bumper support. The whole metal and foam thing on my 93 Z28 weighed 25.6lbs. I'm guessing the one on birds is smaller? Do you happen to have a picture of it?
Old Feb 11, 2008 | 10:18 PM
  #46
InsaneAuto86's Avatar
I still need to do this. My vert is down to 3290 but still has a long way to go.
Old Feb 15, 2008 | 08:53 AM
  #47
LS1TECH Sponsor
__________________
Old Feb 15, 2008 | 08:59 AM
  #48
LS1TECH Sponsor
Thumbs up Pics of new intercooler piping
Re-routed the piping to how ATI does it now, changed from having two coming up from bottom to a single. Makes for a much cleaner install.
__________________
Old Feb 15, 2008 | 09:05 AM
  #49
LS1TECH Sponsor
Thumbs up Pics of relocated alternator
Started with SJM's relocation bracket then made all the spacers in aluminum. Replaced all the hardware with stainless, I would say it looks pretty good! Sorry about the rusty header bolts, they need to go stainless as well!!
__________________
Old Feb 15, 2008 | 01:42 PM
  #50
OWN3D BY MY PROF!
I got some more out of my 93 Z28:
Front Bumper Support = 25.375 lbs
Fog lights and brackets = 4.0625 lbs
Cruise control, cable, and throttle cable cover = 4.4375 lbs
Air pump and brass fittings = 5.9375 lbs
Stock horns = 1.875 lbs
Stock Y pipe and single cat = 21.1875 lbs
My bumper support definetly looks a lot different. Instead of having the foam it has this honey comb type stuff:
Old Feb 15, 2008 | 02:22 PM
  #51
LS1TECH Sponsor
Did you get an initial total weight on her?
__________________
Old Feb 15, 2008 | 04:05 PM
  #52
OWN3D BY MY PROF!
No, I wish I could have. The way I got it though it was taken apart. Granted I'm pretty sure all the parts were in the car, but in boxes. There were also some redundant parts like one stock exhaust manifold was still on, but then the replacement header was in a box in the car. I'm just going to try to keep super accurate records of what I've taken out and get it weighed afterwards.
Old Feb 15, 2008 | 07:36 PM
  #53
Dragframe's Avatar
Damn that engine bay looks good!!
I wish i could get my alternator down there! Just can't with my turbo setup. Anyone know of a driveline drove alternator setup available?
Old Feb 16, 2008 | 06:39 AM
  #54
LS1TECH Sponsor
Thanks and no I haven't heard of a set up like that. Interesting thought though. Only problem is you would have to be moving to make it work. They need to come up with a light weight starter-alt combo!
Old Feb 17, 2008 | 06:36 PM
  #55
LS1TECH Sponsor
Default Some front brake pics
Got the new brakes installed. Don't have the springs installed yet as I am setting up travel limiters. The spindles look good in Jet Hot sterling. Thanks to Lee at BMR for setting me up with new upper A-arms. BMR has made some changes from their first production runs like I had before and they also now have zurk fittings. The brakes line are not run yet but I did pick up a kit from RJ Race Cars to plumb the whole car in stainless with all the fittings for $200.
Jon
__________________
Old Feb 18, 2008 | 04:44 AM
  #56
Jason94z's Avatar
Looks good!
Keep all the parts in case you change your mind down the road. I got old and put back everything this year. Heater, wipers+motor, washer thing, bumpers, etc. etc. and it was annoying that I lost one or two under the dash things. Like the heater core cover. I eventually found everything that was missing on the internet but it would have been nicer if I didn't move two times and lose them. I'm still hunting for PERFECT salad shooters.
Nice engine bay. My car has 5,000mi on it too and it's looking pretty clean. Those miles are mostly driving to Memphis and back for the old event. I'll post some pics when I can.
Good luck remember to keep everything!
Jason94z
1994 Z28 1LE
Old Feb 18, 2008 | 08:19 AM
  #57
LS1TECH Sponsor
Originally Posted by Jason94z
Looks good!
Jason94z
1994 Z28 1LE
The eventual goal is in the 8's so I am not too worried about stock anymore, just want to keep the basics like heat and radio. I have the original tires/wheel combo if you are interested. They are the silver non-chromed wheels though.
__________________
Old Feb 18, 2008 | 09:01 AM
  #58
LT1BRN's Avatar
what a project, good luck with the shedding.
Old Feb 18, 2008 | 09:04 AM
  #59
Ponyhntr's Avatar
I've got a set of perfect salad shooters I may be willing to sell. How much you looking to spend.
PM me if you're interested.
Old Feb 18, 2008 | 10:48 PM
  #60
OWN3D BY MY PROF!
You have the polar opposite desire for creature comforts I do. I just want power steering and ac. Can you take out the heat without removing the ac?
By Brett Foote | 2026-06-04 05:00:17
