160 thermo vs stocker
well its simple the 160 Thermo opens at 160 degrees which keeps the engine cooler and is recomended if you use hypertech programmer. i think the stock thermo is 180 Degrees maybe 192 im not sure.
You can run any w/o a tune, it's just how WELL it runs. I'm sure it does impact your fuel and combustion enough to make a bit of a difference, but probably not a huge or noticeable one. I wouldn't doubt it having an impact on your emissions though. Whether or not it prevents you from passing, if you previously did, is another story (unless you were borderline).
Originally Posted by StealthFormula
^^I'm doubting all that I use to have one in my '95 no problems. I wouldnt run one without the computer tuned for it though personally.
Originally Posted by Ironxcross
i heard it makes the car run richer, reduces mileage slightly and might not let you pass emissions. any truth to that?
It may reduce gas mileage slightly simply because you will get better mileage with the engine running hotter, but you won't make as much power. I would guess the difference would be very small though.
The emissions thing is kind of the same idea, to pass emissions you need to heat things up enough to warm the cats before the test, I don't see why it would affect that significantly though as long as its been running for a while before the test.
I'll be the first one to chime in and start to correct you.
For starters, you can't tune for the Thermostat itself, but everyone here knows that. You tune for the conditions the lower temperature gives. Cooler air is more dense, and dense air is MUCH better for cars. You get more power, better fuel economy, and much better combustion. The reason why it's not exaclty "good" to run a 160 w/o a tune, is because the computer is under the assumption you're running the stock stat, and it'll still calc out everything with that in mind. You tune it for a 160 and you then get to factor in all those new things. Thats why running a 160 is such a good idea, and why most smart people with a Carb motor (who don't really worry about winter time), run a 160. The reason it's nice to run a hotter stat in winter, is simply to have warmer heat
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
All those factor into the power, emissions and gas mileage.
The thermo has one function, it opens to allow coolant passage when the specified temperature is reached. It has zero interaction with any electronic components or sensors.
1 Post
I have tuned a lot of LT1 cars and there is absolutely nothing in the ecu settings (at least that are programable) that has to do with the density of the air or such things that needs to be changed just because of a different temp thermostat. There are a few tables that deal with coolant temp that could possibly be optimized but that's definitely not a necessity.
1 Post
running a richer mixture will reduce gas mileage, but a 160 t-stat won't cause that. the PCM tells the car how rich to run. the mixture is not correlated with the coolant temp because the 02 sensors define what air/fuel ratio to run at. you can have 32 degree air entering the intake plenum (very dense air!) which, in-turn, calls for more fuel per air ratio. or you can have 120 degree air (not so dense) which will mean less fuel per air. however, the that doesn't mean a different A/F ratio. you'll always be running 14.1:1 or whatever it's set at. coolant temp doesn't change how rich the mixture (unless your definition of a "rich" mixture is having higher surplus of both air AND fuel together... then yes is will make a "richer" mixture but that's not standard definition..)
Of course I know the ECM doesn't have anything to do with the TStat. Thermal Mechanics do.
Just because you've done multiple tunes, doesn't mean you understand. I know I sure don't. Just because something in the ECM doesn't directly relate to the operating temperature, doesn't mean it doesn't effect it. As you said yourself, you could run lower timing since it's not as prone to pre-detonation. I would most certainly consider the VE tables to deal with the temp of the engine. Why? Well because the VE table is dealing with how much air the motor and take in and then exhaust. By knowing that it will adjust the air:fuel ratio. Running a cooler TStat lets the incoming air be cooler. Cooler air is more dense, and denser air means more is getting into the engine. So you adjust the VE tables to account for that increased air density. In a carbed motor, you adjust the appropriate screws. If I understood all the tables in the ECM more, I'm sure I could figure out more related things as well.
To clear up any other misunderstandings, I never thought that changing the TStat would hurt a motor in any way. Only the power and/or gas mileage (and by association the emissions).
EDIT: Typo. Also, forgot to add that cooler intake air temp helps exhaust temp too, which means freer flowing exhaust. (Thats why you use exhaust wrap or splurge for the ceramic coated headers.)
The VE tables might apply to yours (93) but they really aren't used on 94+ MAF cars.
And I wasn't claiming to understand everything, however I do maintain that there is nothing of appreciable significance that needs to be changed just because of a different temp thermo. I think if there was that would be well known by now, but the only thing I ever see recommend is the fan temps, which does help but in another way.
