help with crank pulley
k so i'm changin the opti and i cant get the damn crank pulley off, already have all three 16mm bolts off and the thing will not budge one bit. goin off of this write up here http://wiki.ls1tech.com/index.php?ti...lace_Optispark
The way I got mine off is to tap it with a hammer and then spin the motor and tap again to keep it square just do that til it pops off. Before you put it back on clean it up with sandpaper and slap some grease on it makes it alot easier the next time.
Originally Posted by I8ASaleen
Any tips on removing the crank pulley hub? Mine is like completely rusted on, even after leaving Fab blaster on it for a day it still won't come off with a 3-jaw puller.
you dont mean the bolt thats already screwed in there, do you? im in the process of taking it off too, and i thought that held the hub on....? (along with it being pressed or whatever...)
