cam bearing possibly HELP!!!!!!
Old May 23, 2007 | 12:28 AM
josh3111's Avatar
Default cam bearing possibly HELP!!!!!!
I don't think I broke in the hotcam enough when I first installed it. Now my oil pressure drops to zero when it idles after being hot. when I am cruising it is steady at 20 but goes no higher. I can smell something burning, and I found metal in my oil filter. Could this be a cam bearing and if it is, what else may I have messed up and what should I do? Try to repair or buy a new block..also did I roach my cam? I haven't took it apart yet, I am just wondering what to expect.
Old May 23, 2007 | 03:35 AM
daniel6718's Avatar
definately dont run it...how much metal in the oil? you need to drain it immediately and use a magnet catch what metal comes out in the oil and show us,
youll prolly ahve to remove the cam and inspect all the bearings and valvetrain...
Old May 24, 2007 | 01:25 AM
josh3111's Avatar
there is not a whole lot of metal, but it is noticeable....the oil looked grayish,,,and you could see tiny tiny flakes on the oil pan as poured it out...there is no knocking or tapping sounds
Old May 24, 2007 | 01:40 AM
94z28L's Avatar
get pics, if its grayish that usually isnt a good sign
Old May 24, 2007 | 06:34 PM
rob97ss's Avatar
Welcome to the spun bearing club..I know it sucks,but now you can build a 383..
Old May 27, 2007 | 08:54 AM
josh3111's Avatar
how long are you suppose to break in a new cam like that so this doesn't happen again?
Old May 27, 2007 | 11:10 AM
1994Z28Lt1's Avatar
it isn't a matter of not breaking in your cam long enough, with roller lifters you really dont have to do much break in at all just after startup run it up to like 2000 rpm for a little while so that you can get some oil splash on the cam and then it is pretty much ready to go
you really only have to worry about breaking a cam and lifters in is if you are using flat tappet lifters in which case on first start up you run it up to 1800-2000 rpm for about 20 minutes to make sure you get oil splash on the lifters and cam for lube as well as getting the lifters to rotate.
being as how you dont really hear any knocking of any kind i would bet on you spinning a cam bearing, probably from not keeping things clean enough when you installed the cam or you severely nicked a cam bearing when installing it
Old May 27, 2007 | 12:00 PM
Ls1Bait's Avatar
^^^yea
until you get in there and find out the cause of the metal shavings you wont know what is your best bet for rebuilding. I would just start taking it apart and see if there is particles in the oil pickup screen (like gasket material or other crap)
ohhh and welcome to the blown motor club
Old May 28, 2007 | 02:11 AM
Tiger2o69's Avatar
I had this problem with mine motor.. The 2nd cam bearing walked backwards.. The 1st one come apart and this caused issues with the mains so everything had to be replaced.. good luck.. oh the flakes I had were not metal..
Old May 28, 2007 | 01:43 PM
97LT1's Avatar
what color are the flakes? Brass? I used assembly lube when I did my cam install. Maybe not neccessary, but made me feel better. After that I did an oil change since I needed one anyway.
Old May 28, 2007 | 05:57 PM
josh3111's Avatar
the flakes looked grayish silver.....
so since the bearing is spun...is that why I am smelling burning...???what is burning?
Old May 28, 2007 | 05:58 PM
josh3111's Avatar
Oh and what would you guys suggest replacing..on the rebuild..while I am in there...I have the hotcam kit so I have allready replaced rockers and springs
Old May 28, 2007 | 05:59 PM
josh3111's Avatar
Oh and will I have to pull the entire engine?
Old May 28, 2007 | 06:08 PM
daniel6718's Avatar
t orebuild yes...how do oyu know it spun a bearing? id would only replace the bearings/rings/gaskets/ and mayb relap the valves/clean to insure good compression
Old May 28, 2007 | 08:12 PM
josh3111's Avatar
I guess I don't know for sure it is a spun bearing..but it is sounding like it is
