LS1 pacesetter Y-pipe works with LT1 pacesetter longtubes?
Old 06-04-2007 | 02:54 PM
Ironxcross's Avatar
Default LS1 pacesetter Y-pipe works with LT1 pacesetter longtubes?
question is in the title
Old 06-04-2007 | 08:23 PM
Rowdy94's Avatar
No. LS1 and LT1 long tube headers come off at a different angle.
Old 06-04-2007 | 10:25 PM
LT1's Avatar
LT1
good question because i want to buy the Pacesetter LT but i would like to know excatly how to run them back, since they dont sell a Y pipe for the LT1's.
Old 06-04-2007 | 10:32 PM
RedRocketZ28's Avatar
As far as I know they do.
Old 06-04-2007 | 10:35 PM
Bones Z28's Avatar
http://store.summitracing.com/partde...rt=PSM-82-1161
Old 06-04-2007 | 10:42 PM
Bones Z28's Avatar
As for the original question. Yes the Y pipe off of a LS1 set of pacesetters will fit your LT1 pacesetter headers. Go look and compare at summit, there identical. What you have to worry about are the ports. LT1's have a "D" port while the LS1's are oval shaped. The headers on a LS1 will not fit on a LT1, vice versa. However, the with the Y pipe situation, you'll be fine.
Hopefully you already have the Y pipe or struck a good deal otherwise just order all the LT1 stuff together. That's why I love summit, they list everything in one shot, not piece mealing everything together.
here's the LS1 y pipe.
http://store.summitracing.com/partde...rt=PSM-82-1163
Old 06-04-2007 | 11:16 PM
LT1's Avatar
LT1
thanks, i didnt know summit had them.
Old 06-04-2007 | 11:31 PM
Ironxcross's Avatar
so... an ls1 y-pipe fits LT1 pacesetter longtubes?
Old 06-04-2007 | 11:38 PM
StealthFormula's Avatar
^^no the long tubes come out on a different angle just like Rowdy94 said.
Old 06-05-2007 | 12:06 AM
Rowdy94's Avatar
That's incorrect.
Old 06-05-2007 | 12:19 AM
LT1's Avatar
LT1
so how does the O2 sensor plug into pacesetter LT? do i need to get 02 extention wires?
Old 06-05-2007 | 12:30 AM
Rowdy94's Avatar
There is a welded bung that comes in the collectors. If you are handy with soldering and shrink-wrapping, then you can use the extension kit that comes with the PaceSetters.
Old 06-05-2007 | 01:17 AM
LT1's Avatar
LT1
ya i can do little bit of it, thats what i wanted to know. thanks
Old 06-05-2007 | 02:41 AM
the_merv's Avatar
You miss the part in the Summit pic that says: "Image is a representation of this part. Actual part may vary."
LT1 Headers are your standard SBC profile, the LS1 Headers are similar to Big Block Headers for looks.
LS1 Head Exhaust ports are actually Circle shaped, as well as the Truck Head Castings.
The LS6 and LS2 Heads have D-Ports, as well as the LS7 and late model L92 Heads.
Old 06-05-2007 | 05:25 AM
Ironxcross's Avatar
ahh ok, thanks guys
Old 06-05-2007 | 08:14 AM
dhdenney's Avatar
Yeah I tried an LS1 Hooker Y on my Hooker LT1 headers and they did not fit. Not even close.
Old 06-11-2007 | 10:27 AM
B4CZR2's Avatar
Pacesetter sells Y-pipes... I have one in my car
Old 06-14-2007 | 03:27 AM
LT1's Avatar
LT1
yeah i didnt find them when i looked on there website, but looks like summit has them from "Bones Z28" reply.
thanks though,
BTW: how much of a gain would you expect after pacesetter and Y pipe. 1/4 mile and Hp/tq numbers
Old 06-14-2007 | 09:04 AM
the_merv's Avatar
From Manifolds to LT Headers.. you will notice a big difference. I figure around 30hp.
Here is a pic of the set that came in for my LSX Project. If you can see it, the drivers side it sitting kinda high in the back, that is where it's angled out.
Old 06-19-2007 | 02:12 AM
LT1's Avatar
LT1
ur LT's look nice, what finish is that? do all the coated LT's come like that?
Quick Reply: LS1 pacesetter Y-pipe works with LT1 pacesetter longtubes?
