Just intsalled New headers, can't get them to seal
Hey guys, I just finished doing a butt load of work to my car. I installed a New MSD Pro Billet Opti, Wheel Bearing, Guage Temp sensor, and of coarse a set of off road Pacesetter Headers and ORY. I used copper gaskits for the headers and tightend them as best I could using just wrenches. It is so hard to get to some of the bolts too, so I am not to sure if they need to be tightened more or not. The headers leak on both sides, and both the middle two cylinders. What do you guys think I need to do? I have tried to wrench down on them as best I could, I don't kno if I can give it more or not... I'm going to try anyways
When I did mine I used a half length wrench (not socket wrench) with the swivel built into it...really cool wrenches. Before that though I tried a long wrench and could only get them so far and just left them....it sounded like crap! I dyno'd it like that and came up with 362.....few weeks later took some time got the small wrenches and tightened them up good- now it sounds great and dyno'd at 382! I have the same headers w/ the copper colored gaskets as well. Good luck.
had a similar issue with mine, junk the copper header gaskets, copper is great for head gaskets but can be a nightmare for header gaskets, just get a set of mr. gasket ultraseals, the fel pro equivelant the like
Percy's dead soft gaskets and 1" stage 8 locking bolts.
I've reused the bolts and gaskets a few times now and they still seal perfectly.
(H/C 93 LT1 with Jethot Hooker LTs)
Originally Posted by Revelation Z28
what does it sound like when they leak??
They sound like leaky manifolds. Only now I have headers. I hope that there isn't anything wrong with the damn things, they were a pain in the *** to put in for me. I would have to say the job was harder than installing a cam into an LS1! But they leak, more so I think on the driver side then the passenger side. If you put you hand close to it you can feel exhaust blowing out of them.
Originally Posted by borninatransam
ive always ran two felpro's held together with some rtv and havent had a problem. if that doesnt work then the headers are warped or the head is messed up.
Thanks for all your help with this guys I will be trying a few more things, like a new wrench to throw on them before I take drastic measures
Originally Posted by 1999T/A
I used the stocker MLS gaskets on my pacesetter headers and havent had a leak yet . YOu might wanna try them . YOu have to drill out two holes on the gaskets to get them to work , but thats easy .
Originally Posted by aboatguy
Another vote for Percy's deadsoft aluminum gaskets!! ![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
