too many miles??
I would just build it so you know it will reliable.
If you decide to do it though at least do a compression test first.
do you have to pull the motor out of the car to put a cam in it?
he said cam bearings not rod and main bearings which will be the part that is worn down and go bad...that requires pulling the motor
to the above, its your choice man. i am about to h/c my motor, but i have 4 extra motors at home to build... if i were you, knock it all out at the same time. at least tear down and inspect
