Gen I and Gen II small block differences
Old Aug 25, 2007 | 12:55 AM
Ironxcross's Avatar
Default Gen I and Gen II small block differences
Whenever I go into other forums where the cars are mainly gen 1 small blocks, everyone there either goes big block or gets an lt1 swapped in. What makes the lt1 so "amazing" compared to a gen I small block chevy?
Old Aug 25, 2007 | 12:59 AM
ZONES89RS's Avatar
In-Zane Moderator
Well, the LT1 is a flunky in my opinion with the OPTI, but the deltek system can make up for it. The thing is you have EFI and it makes life better on you when it comes to cold starts/emmissions/fuel economy/reliability. I love my GEN I and will never give them up as long as i can find good small blocks laying around.
Old Aug 25, 2007 | 08:23 AM
Formula350's Avatar
It's not that they're exactly amazing, but they are nice motors. I also wouldn't give it a failing mark JUST because of the Opti. Is it anything great, hell no, but that doesn't make it a failure. A failure of a motor can't still have 150shot put on it with 150K on the ticker, which we all know the LT1 can. After all, there are people here with just that.
My guess as to why people go to Gen II from I, is the similarity between them. Other than a few external block changes (timing area basically), they're pretty much the same damn motor. Many parts still interchange, or with a bit of work, are able to be used still on a Gen II.
If you really want to know the differences, I'd say hit up the Newbie FAQ and Wiki.
Old Aug 25, 2007 | 11:11 AM
96capricemgr's Avatar
The opti is MUCH better than the ignorant kids here will ever realize.
I have personally put about 170K miles on my two LT1 vehicles, and only once id I ever have a problem and it was just a worn out cap and rotor which just caused it too run poor in the rain and the cap and rotor are wear items on EVERY engine that has them.
The LT1 has much better heads than any factory GM ones, this is the single biggest advantage, then the reverse flow cooling and very flexible injection system combine to allow us to run some pretty step compression.
The iron head stock LT1 in my wagon cranked 200psi at 180K miles, is 10:1 static, runs on 87 octane wonderfully, the one in my Caprice with 100K on it and raised compression(11.2-3 milled heads and thin gasket) and custom cam cranked 230psi. Don't know of too many gen 1s that can handle that, 12:1 is not unheard of for a street LT1.
The ONLY drawback to the LT1 injection system is the pcm can not go past about 7000-7200, but we still manage to make some pretty serious HP below that, the times in my sig are with a 6150rpm shift point, so it is making substantial power without revving too high.
Old Aug 25, 2007 | 11:17 AM
MUSTANGBRKR02's Avatar
The opti sucks! ^^^^ You may have good luck with the two you have but the other 98% of people here they go to **** fast! Just try a search. But built right the LT1 can make some great power.
Old Aug 25, 2007 | 12:33 PM
ZONES89RS's Avatar
In-Zane Moderator
You must have no experience with the gen I, it is basically the same, the rotating assys are the same, the blocks are only a little bit different. The LT1 opti is just positioned in a poor place, that is its main fall back. I have had no problems with any gen Is like i have this LT1 I have. The main thing about the LT1 is that it can run higher compression on the street a little easier than a carbed motor. But there is TPI which can do the same on a gen I. It really boils down to preference i guess. If my LT1 craps out on me, hell and high water before i put another LT1 in my camaro, it will be a GEN I or GEN III.
Old Aug 25, 2007 | 01:11 PM
Ironxcross's Avatar
if my lt1 dies, im definately putting in a gen III motor.
Old Aug 25, 2007 | 01:20 PM
buffman's Avatar
Sorry Dude, but many of the opti problems come from simple maintenance neglect. Like a new cap and rotor, and a new vent harness (on vented optis) I had 150K on my original opti. Only reason I replaced it was because I was tearing off the waterpump and figured it'd be nice to have a spare. Friend of mine has 250K on an original optispark. Sure it could use a new cap/rotor, but it's still running. IMO the opti gets a lot of it's bad rep from the unvented versions.
Old Aug 25, 2007 | 01:31 PM
Ironxcross's Avatar
+1 to that.
Old Aug 25, 2007 | 02:18 PM
most go to **** and cant handle high rpm's. poor design that is why it only lasted a few years. Just like with everything there are some that survive and last forever. But try a search.
Old Aug 25, 2007 | 02:34 PM
dhdenney's Avatar
No one has said reverse coolant flow. That's why LT1's had more compression from the factory than previous generation(s).
Old Aug 25, 2007 | 03:18 PM
Captainofiron's Avatar
I think what caprice was referring to when he said that the LT1 can take higher compression than a Gen 1 engine was that you dont have to run race gas to get driveability out of it.
LT1s run 12:1 with premium and no detonation
Gen 1s can run 12:1, but good luck doing that with pump gas
Old Aug 25, 2007 | 03:29 PM
buffman's Avatar
Obviously not all are going to have a 100% survival rate. A lot of guys spinem over 6500rpm. Heck I recall Ellis going back to an Opti.
Old Aug 25, 2007 | 03:33 PM
No the thing is these forums are filled with STUPID kids that just repeat everything they hear so when 1 in 10 optis goes bad they blow it out of proportion and neglect to mention it was 100K old.
None of the LT1 cars I have ever worked on have ever had a quality or design issue with the opti, I have a lot of friends with LT1s, hell I have a lot of friends that own multiple LT1 cars. A friend and his wife both daily drive modified Caprices, had tranny problems, axle problems, brakes, but never an opti.
I think people are also too quick to want too overev, my car runs what it does and has never seen above 6500 rpms even during a shift, the opti on it has 80K on the base and 12K on the MSD cap and rotor every bit of that with this heads and cam package.
I am speaking from actual experiance here, not some kid who read something once, not some kid who did something WRONG and blames the parts.
I had mentioned the reverse flow cooling already too, I just think that the credit for the compression capabilities needs to be shared with the injection system and the opti for that matter, it is much more accurate than the HEIs due too the shorter drive system with one less set of gears.
I also recognize the similarities between the motors, I have actually pointed out to folks that 2 piece rear main cranks can be used in this block, and I have many times told people who wanted to carb an LT1 that without the injection the LT1 is little more than a gen 1 with reduced head and intake selection. Like I said here the reason it makes power over factory gen 1s is simply better heads, otherwise they are very similar.
I have struck a better balance of research and experiance than most of you, some of you just slap all kinds of junk together without research, others get all caught up in the bad info presented my the majority of posters on forums, the guys that actually go fast for a reasonable amount of money strike a balance between research and experiance. Have too be able to sort through the 10 kids who just bought the car a week ago saying the opti is crap and realize the 3 guys who have had their cars for 5-10 years might know a bit more, that is why the SEARCH function is not the best source of info. You have to put the time in to know who is a stupid kid and who has the experiance and knowledge to backup their opinions.
I was one of the stupid kids at one point, I am just man enough to admit and learn from my mistakes and then identify who is posting good info and learn from them.
Old Aug 25, 2007 | 03:48 PM
dhdenney's Avatar
Oops missed that in my skimming.
Old Aug 25, 2007 | 04:09 PM
Can't blame you for skimming, the level of stupidity in the average post makes it hard to read it all.
Old Aug 25, 2007 | 04:11 PM
dhdenney's Avatar
I complain more about the location of the opti more than its sheer function. Just kinda aggravating getting to the pass side wires. I do have to kinda agree that putting a "distributor" under a water pump is a risky spot. However, being careful and doing preventative maintainence goes a long way.
Old Aug 25, 2007 | 05:06 PM
i have never owned a LT1 and i am a young stupid kid forgive me.
Old Aug 25, 2007 | 06:13 PM
Zralou's Avatar
I have 164,xxx miles on my Firebird, which has the UN-vented Opti, and its never been replaced, and its daily driven.
My 3rd gen Camaro, just stopped running one day without warning, after walking to work for 3 days until I could work on the car at weekend, it turned out to be the Ignition module (in the HEI).
Sara Lou
Old Aug 25, 2007 | 09:48 PM
buffman's Avatar
dh IIRC I think nissan used a very similiar unit to the optispark on one of their older engines. Its doom was placement. Somewhere near hot oil IIRC.
