Engine turns but wont start........
Old May 30, 2003 | 11:03 AM
mighty mex's Avatar
Default Engine turns but wont start........
Finally put my new motor in and hooked up everything.
I got spark at the coil and at the plugs. Fuel press. is at 35-40psi. New opticrap, new batt.
Motor turns over and spits and sputter through the headers but wont turn on. Valves are set correctly cam and crank are dot to dot. Spark plug wires are in the proper place where they should be. I am running out of ideas. Anyone out there might have an idea let me know. Thanks in advance.
Old May 30, 2003 | 03:49 PM
The Big Show's Avatar
Default Re: Engine turns but wont start........
What year is the car?
Old May 31, 2003 | 12:40 AM
mighty mex's Avatar
ita a 97 model
Old Jun 2, 2003 | 01:01 AM
Gangly's Avatar
how old is the gas in the car, are you 100 percent positive you have the wires on the right cylinders, are the plugs gapped correctly, are there any leaks along the intake path after the MAF sensor, have you disconnected the fuel lines from the intake and activated the fuel pump to see if the fuel is flowing freely through the lines, did you lube the air filter(possibly too much causing the engine to starve)?
Old Jun 2, 2003 | 01:23 AM
mighty mex's Avatar
i am 200% sure the wires are in place, even if there was a leak after the MAF the motor should still start, it will run like crap but it should still start. new air filter. im thinking its the dam fuel. i still need to check to see if the injectors are spraying.
Old Jun 2, 2003 | 11:08 AM
96SCTA's Avatar
This is what i would do. Unplug the maf. TRY starting the car. After it dont start open up the tb blades and take a smell. If you smell lots of gas then your getting gas. Another thing to try is. Hold downt he gas pedal all the way when you start it. I had a hard time starting the car after my build this summer. And this trick worked. Once it starts let of the gas and hold it down to what ever you need inorder to keep it running for a while. Did you check to see if your getting spark at all the plugs. You will know if you have them miswired casue right before it goes to start you will hear the motor kick back. Let us know how you make out
Old Jun 16, 2003 | 09:38 AM
red jet's Avatar
PROBLEM FIXED. COMBONATION OF SEVERAL PROBLEMS: BAD GAS, GAS SOAKED SPARK
PLUGS, VALVES ADJUSTED TO TIGHT AND LOW CHARGE ON BATTERY. IT'S ALIVE AND SOUNDS REALLY MEAN, WATCH OUT STREETS ON HOUSTON MIGHTY MEX IS COMING TO GET YOU.
Old Jun 16, 2003 | 05:34 PM
96SCTA's Avatar
im glade to see you got it all done. how does she feel.
Old Jun 16, 2003 | 06:15 PM
mighty mex's Avatar
dont know yet
gotta get new shoes for it first
but it still wont be out on the streets too soon
going to the body shop in about a week or two.
