Give me some Grab
Old Sep 27, 2007 | 06:08 PM
Bandit 1's Avatar
Default Give me some Grab
My 94 with the m6 will not hook up at all, any suggestions would be great.
Old Sep 27, 2007 | 06:17 PM
Badazz 97 TA's Avatar
subframe connectors, nittos and a strong 10 bolt
Old Sep 27, 2007 | 06:22 PM
SincalT/A's Avatar
strong 10 bolt in our cars is an (oxymoron)
Old Sep 27, 2007 | 06:53 PM
Pntbll309's Avatar
More info on your car would be good. But some better tires Im sure MT ET streets would hold up pretty well.And build your suspension. Hp means **** if you cant hook it.
Old Sep 27, 2007 | 08:01 PM
koolaid_kid's Avatar
Just be sure and have 2.5k set aside for a 9" when you finally hook.
Old Sep 27, 2007 | 08:20 PM
StealthFormula's Avatar
If your talking on the street then suspension is really what you need, Lower Control Arms, LCA Relocation Brackets, Torque Arms all will help with that. If you mean the track then some Drag Radials would help alot as well.
Old Sep 28, 2007 | 04:48 PM
Bandit 1's Avatar
Thanks for all the info, as far as the car. 94 Trans Am with an LT1 and M6. As far as the gears go haven't a clue. Here's the vin tho if anyone can tell off of that.
2G2FV22P6R2236802
Old Sep 28, 2007 | 04:49 PM
Bandit 1's Avatar
Forgot have 18" wheels with a new set of Falkens, She spins them off all the way through third Gear
Old Sep 28, 2007 | 04:56 PM
If the gears werent changed in the car then it has 3.42's factory
Old Sep 28, 2007 | 05:07 PM
Mattybz28's Avatar
These should work.
Just make sure you rev to about 6 grand then dump the clutch.
Old Sep 28, 2007 | 05:50 PM
ThoR294's Avatar
Originally Posted by Mattybz28
These should work.
I lold
Fat tires, sub frame connectors, torque arm... etc. etc.
