SBC gasket on an LT1?
Old Sep 27, 2007 | 11:48 PM
thebufenator's Avatar
Default SBC gasket on an LT1?
I need some help choosing a head gasket now for my 383.
4.03 bore
3.75 stroke
56cc chambers
5cc dish pistons
non-decked block, I know I should have had the block zero decked now,
but owell.
I have heard the average to be about -.025 in the hole.
The heads have also been milled .002, I assume that means I take .002
off of the quench....
The gasket set I have now are they .029 Impala set.
Using those I will have about 11.87:1 compression with a ptv ~.052
using the Mr Gasket .026, I will have 11.97:1 with a ptv of ~.049
Neither of those have the best ptv really.
Now, I heard I can use SBC gaskets, but I will have to open some of the holes.....is this possible?
If it is, I can use either an SCE or Felpro .015 gasket.
That would give me 12.35:1 with a ptv of ~ .038
Will this work?????
I really like the last idea....but not sure if it will work.
I have not yet picked a cam yet.....but its a daily driver, and I like to get on the gas I dont want to spin past 6500rpm though.
thoughts?
Old Sep 28, 2007 | 06:01 AM
jasonisdn's Avatar
cometic will make custom thickness gaskets
Old Sep 28, 2007 | 09:46 AM
I heard cometic didn't go thinner then .027..... and if my deck is around the average of .025, then I need something smaller
Old Sep 28, 2007 | 10:53 AM
dhdenney's Avatar
What head has 56cc chambers?
Old Sep 28, 2007 | 11:04 AM
jasonisdn's Avatar
i just know they offer custom thickness. i never called to see how thin they will go. i don't think the .027 is a custom gasket. they claim any thickness. http://www.cometic.com/custom.aspx
Old Sep 28, 2007 | 11:22 AM
94 guy's Avatar
i have a brand new set of cometic's 4.040 bore and .040 thick $110.00 shipped.
Old Sep 28, 2007 | 12:17 PM
dhdenney's Avatar
That's way thicker than he was considering.
Old Sep 28, 2007 | 10:15 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
1. SBC gaskets can be made to work on the LT1 with some modification, but I recommend buying the correct gaskets instead. Some brands may not seal properly near the holes at the top corners.
2. Cutting the heads will not alter the quench, only the compression. Only the block & gasket will change quench.
3. I would not sweat the gasket thickness too much. Use the thinnest LT1 gasket readily available & be happy, or get the block shaved.
4. Very thin gaskets may not give the best seal either. The thinner they are, the less they are able to conform & seal.
4. The PTV is what I assume to be piston to valve. You need to check it at the piston valve relief, and only in direct relation to the cam timing. If claying the piston top & getting this small reading, you will have problems. Measuring the valve to block deck clearance is useless for determining operating conditions.
Old Sep 29, 2007 | 12:40 AM
Thank you, that was a big help!
I will be measuring how far in the hole my pistons are tommorrow now that I am home for the weekend and can take a look at the block...
Old Sep 29, 2007 | 05:34 AM
dhdenney's Avatar
Seriously, what head has 56cc chambers? Are these custom chambers?
Old Sep 29, 2007 | 02:10 PM
LE2 heads that I am getting used.
Old Sep 29, 2007 | 02:12 PM
dhdenney's Avatar
I didn't know Lloyd opened up chambers on his heads unless this was a custom request.
I really dont know, thats what the guy said that I bought them from.
I might double check it though
Old Sep 29, 2007 | 02:17 PM
dhdenney's Avatar
Yeah that's why I ask that question. Perhaps he is mistaken and your calculations are now all wrong! Stock is 54cc I think so they shouldn't be any more than that. I believe a simple call or e-mail to Lloyd might tell you more. He might say something like "I have never opened up combustion chambers!" Then you'll know. He might even tell you exactly how much they are milled if any.
