First time at the track with the now M6
NOW here is my question after the first run (spinning through the 8th) i decided to do a back to back run pulling right back into line without waiting.. did a better burnout.. hooked a little better THENit was slipping like a sob.. everytime i shifted it would still be up in the redline.. i was pretty sure my clutch was done
got to the end of the track and it was smoking like a chimney real bad.. my car smelled like a fried clutch for 3 hours.. BUT when i was leaving the track.. every gear shifted strong not a single slip at all.. so is my clutch fine? it was smoking BAD.. any advice would be awesome guys
this happened about 2 times, ever since then, its never happened.
i shoulda payed more attention in clutch class
So after u went to the track, it feels fine now?
I wouldn't be too worried if its acting fine now. Generally stock clutches arn't made to be beaten on like that at the strip
its not a "stock" clutch.. its a HAYS clutch thats supposed to be 40% stronger than the factory one..
there is only 200 miles on the clutch
