Remove Lt-1
Old Oct 11, 2007 | 07:14 PM
CAMAROFREEK2's Avatar
Default Remove Lt-1
JUST BOUGHT THIS 95 Z-28 WHATS THE BEST WAY OF TAKEING THE ENGINE OUT? I'VE HEARD ALL DIFFERENT WAYS OUT THE BOTTOM OUT THE TOP IT LOOKS LIKE IT COULD BE A PAIN IN THE ***! LET ME KNOW THANKS
Old Oct 11, 2007 | 07:39 PM
thebufenator's Avatar
out the bottom
Old Oct 11, 2007 | 08:12 PM
1slowZinthe513's Avatar
yea i pulled mine out from the bottom... i only had small problems like getting the brake lines off.. but over all it was easy
Old Oct 12, 2007 | 01:29 AM
ws6t3rror's Avatar
out the bottom, had mine old one out and my new one in and buttoned up from 10am to midnight last time i did it.
Old Oct 12, 2007 | 01:31 AM
Transamman25's Avatar
bottom .. top side can be done but its a pain .. bottom takes maybe 4 hrs and its easier to put in as well
Old Oct 12, 2007 | 04:21 AM
skinnies's Avatar
Do a search next time....
https://ls1tech.com/forums/lt1-lt4-modifications/781126-i-need-pics-engine-being-pulled-bottom-please.html
Old Oct 12, 2007 | 06:37 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Out the top, mega easy. I have seen some goofy set ups with out lifts but thats down right scary.
A engine picker, removal of from accessories, Harness, exhaust, engine mounts and bell housing to engine bolts and it comes out just fine. YOu could un bolt the hood shocks, let the hood flip back and remove the cowl plastic too.
Old Oct 12, 2007 | 10:29 AM
Red96TA's Avatar
pulled through the top...with the trans...never again
Old Oct 12, 2007 | 11:19 AM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Drop it out the bottom, its honestly the only way to do it, took me five hours with a lift taking my time.. It wouldn't have taken much longer without the lift...
Old Oct 12, 2007 | 01:13 PM
Speed Density's Avatar
hashtagBMW
Everybody likes the bottom eh?
Ive done 3 out the top (As well as installed the top) and none out the bottom.
Its all preferance and the tools you have at hand.
Tony.
skinnies's Avatar
I can go out the bottom in about a hour and 15 minutes to an hour and a half now, thats with no lift or power tools either.
Old Oct 12, 2007 | 02:57 PM
bowtie350_428's Avatar
Without a lift??? I have never jack stands that would be tall enough to raise the car that high. I'm not trying to call anyone a liar, I just can't see how it can be done without a lift.
How is it done without lift?
Does someone have pics using jack stands?
Old Oct 12, 2007 | 03:05 PM
Nevermind. Sorry skinnies. I just saw your post at
Engine out the bottom
Looks kinda scary but I am now a believer.
Old Oct 12, 2007 | 03:13 PM
AR15 guy's Avatar
I did mine from the top. It wasn't hard.
Old Oct 12, 2007 | 04:38 PM
gpss02's Avatar
yeah i did mine from the top as well. the motor and tranny came together by accident. it was my first time messing with an lt1 and found out that the tranny won't come apart unless you undo the clutch fork. so after twenty mins of trying to pull it apart i finally just tried pulling them both out together and i was using a forklift from work and chains, along with someone angling the tail of the tranny and it came out in like five or ten mins of messing with it.
Old Oct 12, 2007 | 04:52 PM
LTBANDIT's Avatar
bottom, too easy, even the manual tells you to take it out the bottom...
Old Oct 12, 2007 | 06:05 PM
skinnies's Avatar
We've pulled 25 of them without a lift and never had one problem. The key though is our cart we use.
