LT1 vs LS1
Not its not! Its crappy post and shitty advice to give somone
He is simply out launching and out driving his freinds
Look at a dyno graph of a stock LS1 and look at one of a stock LT1
LS1 makes power all over, look at were there power bans are]
Ls1 is that much better period
Bottom line. Superior is not the word. The only hp gain exception is the heads. Talk to someone that has a custom set of 18* LT1 heads on their LT1 and you will see the LS1 get knocked down severely. Port design helps the LS1 a little bit but the 18* vs. the 23* is where the hp difference is.
At that point its not longer a LT1 its a SBC with FI
Crank, rods, pistons, cam (assuming it's roller) and a few small other things should port over from the 357 in your sig. Well other than the Flowie
I've owned one lt1 and i'm on my second ls1. I really liked my lt1 96' camaro m6. It was a solid runner and very inexpensive. With a 503 cam and 125 zex nitrous my best run was 12.0 with a 1.8 60', that was without head work and on stock manifolds with pcmforlesstune. On the nitrous it made a little over 400 rwhp and the same torque on a conservative dyno. The cons of that car is i went thru 3 distributors which was a huge pain in the butt in only a 30,000 mile period.
My ls1 cars are by far much stronger runners. My 2000 camaro with cam and 150 shot HSW ran best of 11.2 with a 1.58 60'. That was with the full suspension and rear pulled right out of the 96 (12 bolt) and the exact same tires and rims, so they would be older tires since i used them the year prior with the lt1 and bought them used. The camaro on nitrous (only a 25 shot more size then the lt1) had 500 rwhp and 500 rwtorque. I ran a 150 shot on that car many times without a problem at all. I haven't ran the trans am so I can't say how good it runs.
The lt1's do not have more torque stock. If everyone can agree that the ls1's have more horsepower then they have to have more torque since horsepower if a calculation off of torque and rpm.
Good luck on your choice but i don't think you'll be dissapointed with either choice.
I really dont understand stand were your getting that from? Ive scene both cars pop head gaskets etc
FYI there are 300shot stock bottom end LT1s and LS1s around here with no problems....You car just needs to be tuned well for it and you have to know what your doing..
600whp FI is being done with stock bottom end LS1s also
ITS ALL ABOUT THE TUNE!
