Does Opti rotor orientation matter on installation?
Does the orientation of the rotor matter on install? In other words, given the old Opti's rotor was pointing say at 12 noon on disassembly, does the new rotor need to be in that same position?
I know the LT's have a camshaft and a crankshaft postion sensor and the Opit has two wheels (high res and low res - my low res has failed BTW), so like with a standard distributor is this orientation just as critical, or is it just a reference thing?
I only want to do this once! Thanks in advance (no pun intended)!
MIKE
1995-1997 vehicles use the 'vented' optispark, which is driven directly by the camshaft dowel pin instead of the splined shaft to which you're referring. There are three slots on the back of his optispark, one of which has an indexing mark.
THAT's when you follow MrElectric's post!
On 1992-1994 vehicles, there's a short splined shaft affixed to the camshaft timing gear, which protrudes through the timing cover, and has two flattened teeth to serve as an index. Those flattened teeth mesh with the corresponding splined connection within the 1992-1994 optispark.
Yes! Yes, the damn optisparks only install one way, which is why I bothered mentioning the *indexing mechanisms* of both styles of optispark. If you don't index it correctly, you've installed it incorrectly. This is really, really simple.
I'm sorry, but these are the best photos I have on this computer:
1992-1994 Optispark drive (pictured here with the splined shaft inserted into optispark, flattened teeth only allow the shaft to install one way. Again, the shaft you see here is normally fixed to the cam gear, with the other end of the shaft protruding through the timing cover for the optispark):
1995-1997 Optispark Drive (three larger slots make room for cam gear bolts, elongated or otherwise 'marked' smaller slot accepts the dowel pin):
If you don't understand it at this point, your head has likely collapsed into a black hole, and you should consult a doctor immediately.
i dont know if that last comment was directed at me or in general
It's just a matter of sticking your pinky into the optispark and turning the internal rotor assembly until you think it's aligned with the 'flattened' spline on the shaft protruding from the timing cover. Try lining it up and installing the optispark; if it doesn't sit flush, pull it off and rotate it a hair until it does.
Again, don't pull the optispark on with the bolts. It should sit perfectly flush on the timing cover without coercion. That's all that matters.
In particular, the later ones that use a dowel to like up are easy to screw up by a) putting the dowel in the wrong slot and cranking the oppti down anyway, or b) using a cam with a dowel pin that isnt long enough so that c) the dowel pin gets pushed back into the end of the cam when the Opti is tightened down.
