Heater Box Removal
Old Jan 6, 2008 | 12:14 PM
SpeedDensityZ's Avatar
Default Heater Box Removal
What is the weight reduction for removing the heater box?? Where can I get the block off plate If I do decide to remove it??
Old Jan 6, 2008 | 12:27 PM
the_merv's Avatar
Veteran: Air Force
I would say with everything in it probably about 15-20 lbs.
I made my own plate..kept the Heat though..
Old Jan 6, 2008 | 03:50 PM
Built LT1's Avatar
I removed mine and estimate the weight savings to be approximately 15-20 pounds.
I think Madman Co. makes the block off panel. I can't remember where I purchased mine, but I do know that it was from a company that makes them specifically for our cars.
Old Jan 6, 2008 | 03:55 PM
Sweet. I would really love to keep the heat. Even though I live in Florida it has been in the 20's for this past week. BURRRR!!! Merv, what do I need to keep the heat? I remember reading somewhere that you needed to do something speceific in order to do it.
Old Jan 6, 2008 | 04:03 PM
Built LT1's Avatar
FYI, the weight savings from the part I mentioned was from the box/radiator itself. You'd have to keep it in there if you wanted to retain heat, hence no significant weight savings.
Old Jan 6, 2008 | 04:49 PM
flyinZ's Avatar
You have to remove the passenger side of the dash, dont you?
Burkhart Chassis also makes a delete plate.
Old Jan 6, 2008 | 08:04 PM
MEAN LT1's Avatar
http://www.bmrfabrication.com/misc/FP003-small.jpg
Old Jan 6, 2008 | 11:18 PM
the_merv's Avatar
Veteran: Air Force
Yup..make a little passage way in the Center for the Blower Motor to blow Air into the Heater Core..
Old Jan 7, 2008 | 12:39 AM
Ralls's Avatar
****, I didn't cut a passage between the blower motor and heater core. Gonna need to open it back up
Old Jan 7, 2008 | 02:05 AM
tylert14's Avatar
I had a BUNCH of pictures when I did mine, but my friend deleted them off my camera But I kept the heat as well.
Old Jan 7, 2008 | 10:31 AM
Cool. I wasn't really looking for all that much weight reduction. I was really looking to clean up the engine bay a bit. Thanks for the info guys. I have materials and I will probably tackle that within the next couple of weeks and post up some pics.
Old Jan 7, 2008 | 03:34 PM
T/A KID's Avatar
Get rid of all of it and put in a Mojave heater system.
Old Jan 7, 2008 | 07:28 PM
indirocz28's Avatar
I got rid of my whole box- Merv is the one who guided me through it. - Thanks for the pics man btw!. Also, I gutted my dash out ( i.e. - took out all heating ducts and the pass airbag). The passenger airbag weighs in at probably a good 10/12lbs..So, get rid of the condenser, lines, ac compressor, box, ducts, airbag,- and you lose 40/50lbs!..
But I do miss not having any air flowing in the car for defrost.. I'll fix something up though..
Old Jan 7, 2008 | 09:39 PM
1SlowFormula's Avatar
I made my own block off plate, here are my pics...
http://www.1slowformula.com/HVAC-rad...lete/index.htm
Old Jan 7, 2008 | 10:03 PM
LT1Formula007's Avatar
Looks good everyone....
Indirocz28: Hit me up when you wanna put that dash and interior back together. If you want we can fab up something for your heat.
James
BTW the tune works great man!
Lets focus on the 7* of timing retard next.....
Old Jan 8, 2008 | 08:38 AM
the_merv's Avatar
Veteran: Air Force
Yup...looks good.
Old Jan 17, 2009 | 08:18 PM
needaz28's Avatar
anyone of you guys ever install a blockoff plate with the engine in the car?
Old Jan 17, 2009 | 08:57 PM
TABBED 5.3's Avatar
I did it, but on the inside. I removed EVERYTHING. pretty sure you could do it the other way with the engine still in.
Old Jan 18, 2009 | 06:07 AM
the_merv's Avatar
Veteran: Air Force
It would be a pain in the *** from what I can tell.
Old Jan 18, 2009 | 08:13 AM
needaz28's Avatar
yeah thats what I'm thinking PITA. I'm at idle now till more turbo parts show up. decide to jump into it after a couple beers got it all done then ordered the plate from madman. went back out side and was looking at it, I might just have to put it on the inside and keep everything out till I drop the 6.0l in there this spring.
