94-95 Z28 underhood harness!
I am swapping a LT1 into a 1996 V6 Camaro for my brother, it will be his first car. I have about everything I need except the underhood harness. Not the engine harness, the underhood harness. Does anyone have or know where I could get this harness for a 94-95 Z28? Thanks!
I'm doing the same thing except for a '97. Going to post up some pics later. Keep us posted on how it goes I could really use a good swap guide. Witch harness are you talking about? The battery cables?
If it's obd 2 whats the differance in the body harness from the v6 to lt. I have a 94 v6 that i'm going to do the same thing to after i pull the motor out of my 97. I just planed on getting a engien harness for a 95 camaro and tosing it all in there, but with the obd2 you dont need the emissions to actually work (program out). whats the problem your running into.
I am putting this car together for my brother and he will go off to college next fall. So the thing needs to be set up just like a '95 Z28. That way if there is ever any kind of problem, shops or dealers will be able to work on it like any other normal car. He will just have to tell them it's a Z28. If I was always going to be around, then it wouldn't matter. I would just splice wires and make it work.
