A/C Delete, Do i need a delete pulley or just reroute the belt?
1 Post
Gonna remove the a/c here soon, do i need to buy the delete pulley or can I get a shorter belt or just reroute it somehow?
GM part # 10115875 Cant tell you if they can get it for u or not.
http://www.gmpartsdirect.com/results.cfm
Yea, order the pulley from GMParts Direct.. - mounts perfect, I havent had any problems with it..
And actually, i have alot more room now in my engine compartment!
I had to get a slightly shorter belt with my GM A/C delete pulley. You may find the delete pulley cheaper at your local GM dealer.
WD
WD
