Is a tune necessary for deleting AIR/EGR??
Yes I've tried searching, but is a tune really necessary when you delete AIR/EGR?? Also are there any write ups out there on how to delete them??
For the EGR just leave the vacum solenoid hooked up and the pcm has no idea that the valve is missing. For the AIR just make sure and keep the fuse and it'ts the same thing. No codes or SES light. This works on my 94, but I've heard that obd2 is more sensitive.
NP Eric lol
I tuned out my AIR and EGR, but still I have to keep my solenoid plugged in or it throws a code right away. ARM my AIR is unplugged and out and no codes. As far as the rest of the plumbing I have yet to remove the AIR piping and the actual EGR. I just capped off the holes in the exhaust manifolds. Then again, mines a 93 and differs quite a bunch for tuning. I looked at a 94/95 once and wooo there's a difference!
At any rate, I corked off the solenoid just to make sure, as well as all the other vacuum line places on the intake and even EGR itself.
And Razor, to clarify, you're saying leave the AIR pump plugged in, but just not hooked up?
^ True. I have my AIR taken out and my Check Engine Light has never came on due to that. I took the whole bracket/pump/and etc out of the car. Just had to cap off the AIR tubes with Radiator hose plugs. (Black Rubber caps that you would use to cover up a port on the Radiator if you delete a hose) They are sold at any Auto Zone or Advance Auto Parts stores in the Help sections. They are like $3.00 or so.
Sweet, cause I'm about to install long tube headers on mine and I was wondering if it'll cause any problems. I dont care about the SES light(I took off the bulb on the cluster, lol).
Does anybody have any pictures? I am also deleting the air and the egr on my car also and i would like to see some pictures. If anybody has any, sorry for the thread jack but u think it will help everyone out.
+1 on pictures I just pick up a 95 Z28 and I'm getting ready to spend some money!!!! headers /CAI/Catback and tried to figure out what esle to get with the tax return while I still have it.
Thank-you
Thank-you
