Need serious help!!!
Old Jan 26, 2008 | 04:51 PM
Badboy19's Avatar
Default Need serious help!!!
I keep having water get in my oil, this has been a serious problem now for the past month!!! Any idea on what to do with this and how to stop it!!! ????
Old Jan 26, 2008 | 04:56 PM
chavez885's Avatar
Water AKA coolant? Headgasket?
Old Jan 26, 2008 | 05:02 PM
Badboy19's Avatar
i blew my head gaskets awhile back and now the motor is back together now and i just took my oil filter off and all it was full of was water or aka coolant. I dont know how the filter could be full of water i have never heard of that.
Old Jan 26, 2008 | 05:03 PM
chavez885's Avatar
Have you pulled your radiator cap and checked for oil?
Old Jan 26, 2008 | 05:05 PM
Badboy19's Avatar
no do i just look in the radiator or what??
Old Jan 26, 2008 | 05:06 PM
Badboy19's Avatar
yea there is oil on the cap its like a light film of it. looks like frapachino stuff lol. what does that mean??
Old Jan 26, 2008 | 05:26 PM
gatorhead's Avatar
I means either a blown head gasket, warped or cracked head or block. It also means that if you continue to run your car like that it will be hydrolocked in no time at all!
Old Jan 26, 2008 | 05:33 PM
Badboy19's Avatar
ok thanks guys i will make sure to check it all before i run it again thanks for your help.
Old Jan 26, 2008 | 06:15 PM
98pontiacfirehawk's Avatar
Does your car have a oil cooler, if it does it may be busted in side the cooler.
Old Jan 26, 2008 | 06:23 PM
SLawson86's Avatar
well sounds like a stupid response from me, but after the work did they (or you) change the oil? i have seen it numerous times when after the work it is forgotten to change the oil. and how many times has this occured when you changed your oil? there are numerous things it could be... more info please
Old Jan 27, 2008 | 02:56 AM
gatorhead's Avatar
This is worth checking into as well, but I have a hunch its elsewhere given it's history. BTW you CANNOT reuse the headbolts on these engines.
