look 4 hp#,and some help.
Old Jan 28, 2008 | 01:47 AM
con95's Avatar
Default look 4 hp#,and some help.
I just got a 1995 z-28 the car was a old police car. It has the lt4 hot cam,intake,58tb,ported afr heads with 1.7s ,150 hp nos kit and cold air kit. It also has headers 3" y pipe and borla exhaust.Looking 2 change the rear gears 2 a 373. The trans is getting built stage 4, but do not know what stall 2 get? Fyi 1st camaro,any help would b good help thanks.
Old Jan 28, 2008 | 01:50 AM
96lt1m6's Avatar
3200-3600 vig
Old Jan 28, 2008 | 01:53 AM
con95's Avatar
What kind of hp do u think i looking at? Thank for the help.
Old Jan 28, 2008 | 01:56 AM
9sec93's Avatar
350-375 rwhp
Old Jan 28, 2008 | 02:04 AM
con95's Avatar
What is it going 2 take 2 get in the 11s?
Old Jan 28, 2008 | 02:42 AM
gatorhead's Avatar
A good stall and a dialed in suspension!
Can't say I have ever heard of anyone using 1.7 RR'S and ported AFR'S with a hotcam~
Old Jan 28, 2008 | 04:35 AM
9sec93's Avatar
weight reduction and suspension will get you deep in the 11's. i went 11.70's with just 320 rwhp and 3300 lb. raceweght. as a far as torque converter, buy a good vig, yank, or equivalent 3600 stall. if you skimp on the converter, you will regret it.
Old Jan 28, 2008 | 09:31 PM
con95's Avatar
In Houston where can u buy a vig, yank stall?
Old Jan 28, 2008 | 10:01 PM
95Lwind05's Avatar
Originally Posted by 9sec93
350-375 rwhp
its gotta be more than that...i made 389 granted through a 6 spd..but he also has a cam and some damn nice heads, and more N2O
Old Jan 28, 2008 | 10:36 PM
SS RRR's Avatar
Village Troll
suspension isn't a great concern when dealing with 350 to 370rwhp just as long as the track is prepped. If you're dead hooking on the susp. (on a well prepped track) you have now then changing susp. parts isn't going to do anything better.
Old Jan 28, 2008 | 11:23 PM
speed_demon24's Avatar
What do your #'s on spray have to do with the op's question?
And to the OP, the only way to know is to dyno the car and run it at the track. Hopefully whoever ported your heads knew your combo and did a quality job.
Old Jan 29, 2008 | 10:40 AM
1badzee's Avatar
hmmm hotcam with afr's?
Old Jan 29, 2008 | 11:48 AM
95Lwind05's Avatar
calm down buddy, i was just saying thats what i did, someone said he thought between 350-375, i was just saying he should have alot more than that....if you didnt notice it does say he has spray as well.
