Is this right??
Most of my races with mustangs unless they have a supercharger or h/c i walk away pretty easily too but i have 3.23. maybe you should try gears and a stall before the cam
the gears are really whats hurting you, even if you just picked up a set of 3.42s cheap around here you should put them ponys to shame.
One thing to note for you on gears, is that you'll need to do 1 of 2 things. Buy 2 Series gears, because of your 2.73 carrier being different, or buy a 3 Series carrier and gears. The latter would be easier to do since you could goto a junk yard, or even here, and find a pull. You'll probably want to get the caps and stuff if swap to a 3 Series just in case they're different.
Or, do what I did and swap in a 99+ M6 full rear and get .3" bigger brakes, slightly better posi, and 3.42s
I got lucky though and got a new rear that was going to be used in a project car and he decided not to for $650. No calipers, but had rotors.Also, I bet a tune, even with those gears, would let you beat them.
I believe I might have 3.23s for a 3 Series, from my rear swap. I don't have the carrier anymore because I sold it to a friend for his S-10 project. There's only about a 25% chance I can find the gears though.
lol
