I gotta a Miss under load and high RPMs
Ok, ever since i put my headers in i have developed a miss and sputter at low RPMs in overdrive, and at WOT over 4000 RPMs. i have replaced the fuel filter, which was so stopped up i couldnt blow through it. The coil, which was so corroded i dont know how the hell it was working. The plugs and wires have about 5000 miles on them (ACDELCO) and there is no arcing. And its got a new MAF because i dropped the old one and busted it.
Can the knock module be picking up a false knock with my headers and true duals and cause this miss, or should i go buy a new optispark?
yes it could. tbh my buddies lt1 car does exactly that except his knock is in the tranny (m6) we are probably going to try and rrelocate the sensor and see if it helps. its worth a try before having the tranny worked on. hope this helps you
