How high can a lt1 be revved safely?
wondering what a good safe rev limit is on a stock lt1 bottem end... I dont want to put to much strain on it, esp with nitrous
Welllllll..... Had a problem with the ported MAF, *coughmistakecough*, effecting shift points on my A4 (somewhere in excess of 6,000 rpm at 145,xxx miles on the engine in the 2-3 shift.... racing a steeda mustang no-less) spun a bearing. Like stated its hit or miss. Really depends on how the engine was taken care of.... and unless you're the original owner, prepare for the WORSE.
I'm now in the process of rebuilding (which i have no idea which route i'm heading in), but its always good to have funds ready. Especially if you are racing your daily. Just think twice about how it will affect you.
I wouldn't go much above idle if you want to be safe...
Mine let go in the burnout box feathering in the area of 6800 - 2 rod bearings. Still ran a 12.8 @ 114 cam only with the 2 spun bearings. Died in the burnout box, again at the line, and then when I got on the brakes at the end of the run. It was toast.
Sprayed mine to upper 5k with no issues for quite a while before I cammed it.
6375 on the stock bottom end.
Higher under low traction.
25 or so track passes, plenty of street abuse.
Maybe I was lucky.
(having said that, I'll probably spin a bearing tomorrow on the way to work)
Maybe I was lucky.
yah i wanted to know the 1:1 gear not OD hehe... does anyone know the stock rev limiter on a 1993? and also how to tell symptoms of a spun rod bearing... you guys got me all worried now that I read these motors cant rev haha..
LS1TECH Sponsor
I have a 6400 chip in my MSD and just hit it at the stripes. Highest mph was 118.96 with 28 tall MT E/T street, 4.30 gear, and with a converter with about 5.8% slippage. I shift at 5600 and don't make any power past that, just have a quick first 1/8 mile and drink coffee the rest of the way.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
