went with lloyd elliot
Lloyd tends to put bigger lift cams in, so I think the heads will do better with more lift.
I am still working the kinks out of my setup, its the LE3 with a ported intake.
But the cam is a .6xx/.6xx cam.............so maybe you should go with one of his.
Just trying to be helpful
Either way it should haul ***
If you have not already purchased that comp cam.
Lloyd (or rather Bret) can grind you a custom N20 cam to match those heads and your goals.
I know JoeB runs a custom LE1 cam (similar to my LE1HL)
