1le elbow vs. aluminum
I like the stock look of the 1LE. I was surprised to learn how much larger it is than some of the metal elbows.
so do you guys think i will be happy with my 1le compared to the other one with the resonator? and how much of a performance gain is there? and is it really that much louder than the one with the resonator?
I like my Vortec elbow. Where it meets the throttle body (and a ways up the elbow) it has a divider which can help cut down on turbulence going into the TB. Then again, itself being there (even though it's very thin) still will make a bit of turbulence, but I think it helps more than doesn't.
I doubt you'll notice any gain, and I don't remember any noise change when I removed the 'resonator' (donkey-dong, more of a silencer than resonator). Nor when I went from the stock to aluminum, but the benefit is there isn't any of the ripples in the elbow area in the aftermarket.
The 1LE, and I guess the stock elbow as well, seem to be quite a bit larger than at least one of metal elbows on the market. There is a thread on camaroz28.com that had a photographic comparison, and I think it was actually linked to earlier in this thread. Whatever elbow it was, I think it may have been a Trickflow, looked like it would virtually fit inside of the 1LE. It had a much smaller diamater tubing. I don't know if this is the case for all of the metal elbows.
My Vortec seems really nice, and I recommend it. I bought it for my TPI car, unbeknownst to the fact it just wouldn't fit. Good thing I help onto it! My only problem was the IAT sensor. The elbow is threaded, and my IAT wasn't. Some simple sanding on the IAT plastic and removal of 2 ridges made it thread in so to speak (more like push in) and I haven't had one issue. The diode (or whatever the IAT has) sticks just as far in as a stock elbow.
the flowmaster thing was in response to the guy that said why do people buy the aluminum one's when they're smaller and cost more. But to answer your question I like it so far, only had it a month or so, but I like it though, especially now that I can easily change the rear end fluid, and it gives me a little piece of mind knowing that it'll be harder for me to hurt the rear with street tires.
#34
I didn't realize the metal elbows were smoother on the inside than the stock rubber elbows.
#37
Are you absolutely sure? The rubber may actually flow better due to certain laws of fluid dynamics. I'm also not convinced that the inlet sizes are the same. That certainly doesn't appear to be the case based on the photographs. Imo, it appears to be quite a bit smaller. I think there are some additional pics in the camaroz28.com thread. You should check them out. I'm not trying to be argumentative, but it just seems like you're grasping at straws.
#38
#39
I do see the ridge and I'm still convinced that the 1LE and stock elbows are larger internally than the Trickflow. That's what my eyes are telling me. It would take some actual measurements to convince me that I'm not actually seeing what I'm seeing. There is another pic in the camaroz28.com thread showing the trickflow mating up to a throttle body. And while there isn't a similar pic with the 1LE, the owner of both elbows stated the trickflow was smaller. I don't know the guy, but I doubt he would just lie for the sake of lying.
#40
The inlet portion on the car DOES NOT CHANGE.
Therefore, the car only accepts so much.
So if the intake's ridge was actually 'bigger' it would not fit right, or it would be loose.
Those pictures are 100% useless and prove nothing.
