stripped throttle body bolts
Old Mar 15, 2008 | 09:57 PM
Revelation Z28's Avatar
Default stripped throttle body bolts
i stripped my TB bolts both on the driver's side. does anyone know the thread size so i can re tap the intake manifold?
oh, and yea its causing a huge vacuum leak lol
Old Mar 15, 2008 | 10:26 PM
porksoda's Avatar
Dude you have had an interesting month to say the least!
Old Mar 15, 2008 | 10:54 PM
nemanracing's Avatar
Wow and i though i was having problems with mine... lol i only screwed up my crank bolt and a while back i snapped one of the bolts holding my MAP sensor down...
Old Mar 15, 2008 | 11:07 PM
yea, but so far so good with a new opti harness. only thing that was making me feel wierd was the RPM on idle going to 500-400 when turning the wheel. then i remembered i stripped the bolts lol
Old Mar 16, 2008 | 08:03 AM
James Montigny's Avatar
A couple of these will hold it.
(J/K)
Old Mar 16, 2008 | 08:11 AM
moehorsepower's Avatar
I would not re-tap it, I would install a Helicoil this way you can still reuse the same size bolts.......then tighten the crap out of it...
Old Mar 17, 2008 | 01:05 AM
done and done. ******* helicoil kits are expensive!
Old Mar 17, 2008 | 06:02 AM
Tell me about it, I had to install helicoils in all of my bell housing because the idiot mechanic that worked on my tranny stripped them.!!!
