where can i buy a o2 simulator
my o2 sim went out a little while after installing my l/t headers and i cant find theses things anywhere please provide me with a link if poss.
thanks 96-trans am
thanks 96-trans am
tell me more about it i have no idea what your talking about but did here about this b4.would it interfer with the upgrades i want to do this month or should i wait 1st
thanks
tony
thanks
tony
i have l/t headers/dynomax bullet,cai,msd wires/coil,zex 150shot/mallory retard box. i want to get that cc306 cam put in and whatever else should go with the cam like rockers and ??????whatever else i dont no and a 3.73
Well as I mentioned if it is the post cat O2 then you don't need a simulator unless you want to shut the light off. All a simulator does is trick the PCM into thinking the cat is working properly so the service engine soon light does NOT turn on. If it is an O2 in the header collector then replace it with an AC Delco replacement. That will cause your car to lose performance.
If you plan on a cam and supporting valvetrain and gears soon then wait on the tune and get it all tuned at once from either your local speed shop or a mail order tune would work too. With a tune you can get your car to run great with the cam and mods plus you can delete codes like EGR, AIR, and those O2 codes your probably getting.
thanks 96-trans am
"I'm trying to help you figure out which ones you want to replace"
thanks 96-trans am
Forget it just see if these work (scroll halfway down the page). If not then its your actual O2 sensor.
http://www.ls1speed.com/catagory.cfm.../%20Electrical
i ordered 1 from speed then ups lost my order speed sent another then 2 weeks later ups dropped off the one they lost so i got a freebie its laying here in my box of misc. parts $25 if u want it.
