Building a lt1 for nitrous?
Old Mar 23, 2008 | 11:03 PM
azboostin's Avatar
Default Building a lt1 for nitrous?
SO ive been debating numerous motor swaps... But maybe I should just keep my lt1. I would like to make 450 hp n/a and be able to spray upwards of 300 in 2 stages..... What kind of rotating assembly is needed here? ect...
Old Mar 23, 2008 | 11:57 PM
bigbadblack93z's Avatar
my buddy had a scat 383 cast crank, eagle h beams and srp pistons w/ a cam similar to the 306 and afr LT4 heads. made something like 441 at the tires and close to 700 on a 200 shot of gas. it was indestructible and tuned specifically for spray.
Old Mar 24, 2008 | 09:53 AM
Dave J's Avatar
must have been a 6 speed car.441 rwhp with a baby cam like that is no easy task,Especially tuned for spray.I bet the same motor in my car would make under 400
4 bolt main block or splayed,scat crank,eagle h beams,je pistons and of course all forged.I think as far as topend goes you should go solidroller
Old Mar 24, 2008 | 05:01 PM
azboostin's Avatar
is there anything speical I need to do to rev to 6500 rpm? I want to us a xfi 292 cam, 383 crank, and ported stock heads could i get my goals with this?
Old Mar 24, 2008 | 05:46 PM
97blkz's Avatar
I second that, I bet you're like me and give a rats *** about dynos. The track tells me if my junk works.
Old Mar 24, 2008 | 05:55 PM
96capricemgr's Avatar
With the cost of Eagle forged and the known dimensional issues, better to look at Compstar, far better stuff for similar money.
At least go with Scat it is better than Eagle.
Old Mar 24, 2008 | 11:15 PM
TAEnvy's Avatar
Do you think good forged rods and pistons on a stock crank with splayed 4 bolts would hold up to a 300 hit?
Old Mar 25, 2008 | 01:19 AM
B-Rad420's Avatar
Probally, but maybe like 5 times, lol I think a 300 shot is pushing it on a stock crank. I plan to spray in the future but dont plan to go past 200 on stock crank. If I step it up some I will probally go to a cast steel 3.50 stroke crank for like a 250 shot direct port.
Old Mar 25, 2008 | 02:00 AM
slick1851's Avatar
Lol 6,500? Thats WEAK!!!!!!!!!!!!!!!!
Get a good valve train and bottom end with wicked heads, and let her rev
Old Mar 25, 2008 | 02:02 AM
slick1851's Avatar
Why not? Cranks are pretty strong...
I would do a budget build spray motor since you sound new at it
Shot peened rods, with forged pistons so if you blow it up you wont feel bad and saves you money if there is a problem so you live and learn then you can build the beastly motor after
Old Mar 25, 2008 | 04:23 AM
it was more of a rainy day thing that we had our cars dyno'ed. the car runs like a raped ape. mid 10s on dope and solid 11's NA.
It all comes down to talking to the engine builder and listening to their input on parts. they make money on labor so don't feel like they are trying to screw you when they tell you to buy something expensive sounding. give them a budget and they'll already have a combination for you to use that they know works. If they don't you might want to call another shop.
Old Mar 25, 2008 | 09:40 AM
FASTFATBOY's Avatar
You need a 4340 forged bottom end,4 bolt mains, splayed or stock(vette block)
Nothing wrong with Eagle rotating assemblies, there are probably more eagle bottom ends in fast cars than any other(if I had to guess)
The key here using that much gas is the piston and ring pack location...and the type of ring that needs to be gapped FOR the spray. I would run a Hellfire ring.
You need a dedicated cell with 116 octane to run that much safely. And if you dont know how to run that much PAY someone to show you how to flow the system for each jet setting. And where to set the timing. Do it AT THE TRACK...you can baseline on a dyno, but the car at the track on the spray acts differently than on the dyno, needs to be fine tuned at the track.
You need a GOOD timing retard/ignition box.
I dont feel the need for a solid roller here, the spray will make alot of power with a hyd roller to 6500 rpm.
Just my opinions.
Old Mar 25, 2008 | 05:01 PM
94nitrousedLT1's Avatar
My 383 will see 8000rpms and the pistons/ring combo is set up for 450-500hp if I get crazy. But it is a callies rotating assembly with custom wiseco pistons(12-1). The eagle stuff will most likely hold it if every thing is checked and in tolerance. The eagle stuff has been known to be out of tolerance on the rod and a main journals. A big shot will only need about 20* of timing.
