I'm so sick of these exhaust problems.. I've called jegs, summit, midas.. help!
Ok guys I need help here.
I called summit/jegs and midas. I'm trying to connect my 2.5" exhaust to my 3" collector. sounds simple right? well i thought so too.. just go to autozone get a reducer NOPE. none there, none at murrays or advance either. I call MIDAS and they say they can make me some reducers but they won't have a flare like this one : http://www.jegs.com/photos/389R3025.jpg
all they can do is make me a typical reducer with no flare, like this one: http://www.speedwaymotors.com/eccSto...917-2530_R.jpg would one like this be okay ?
AND THEN! they (midas) told me i can't use a slip fit reducer (reducer slides over collector) because the collector material is to thin and might crush under the pressure of the U bolts i planned on using. Is this true? ... can I just use a regular non-flared reducer and use U bolts to clamp it over the collector ?
I can't use band clamps b/c my subframe is in the way
so what do i do? thanks guys!
If you guys are confused let me know I'll try to explain it better, I REALLLYY need help on this so i can get my car running its just driving me crazy, I have no idea what reducer to use, what type of reducer i CAN use etc..
thanks alot guys.
thanks alot guys.
I really just wanted to use a regular reducer (second pic^^^) and a u bolt and leave it at that you know.
let me know what you guys think!
so what do you mean man just a typical reducer autozone style.. or a flared one,???? ( I don't really wanna spend 40$ on flared ones if possible).
do you think that would cause flow issues or not really ?
do you know what im sayin man ?
its gotta go down to that size anyway it wont cause that much restriction if any. you arent building a race car so if you loose some flow you wont notice it. there are plenty of guys making big power on 3 inch duals goin into single 3 inch.
I believe that flowmaster has a set of reducers that slip on from 3" to 2.5". They have a nice smooth transition but are longer than standard reducers part #389-R3025. They are like $30 for the pair. I used them on my truck and worked nicely.
thats what im trying to connect ...
darn, idk why i didn't think of that, couldn't I just take the 2, 2.5" pipes from the kit and have them flared to 3" i.d. and then just clamp them on there? or is that a bad idea?
haha thats what u have to do! its the easiest way... take ur exhaust to a exhaust shop, be like i have 3" collectors and i need these ends flared out just enough so i can slip them over the collectors and band clamp them on... they will take care of ya for like $20 - $50
