"Stock Internals" Build
Old Mar 29, 2010 | 05:28 PM
  #281
jpstreetracer95's Avatar
great thread. i didn't see anyone ask but i was wonderng about your master cyl setup. i didn't see a booster in the pic. and i assume there is no abs. is that aftermarket? did you guys just fab up those lines into the factory ones or are they all new? i want to get rid of my abs.
Old Mar 29, 2010 | 06:27 PM
  #282
Michigan Skip's Avatar
You could use the SJM kit..
http://www.sjmmanufacturing.com/cam_brk_lt1.html
.I use one, here's a thread with pics.
https://ls1tech.com/forums/lt1-lt4-m...t-up-pics.html
Old Mar 29, 2010 | 06:50 PM
  #283
BADHAWK51's Avatar
Originally Posted by AChotrod
I hope so! Depending on how I feel after work I might test fit them real fast.
Mike I ran those tires on my car and they would rub under normal driving. I would get the bfh to make some room. Also make sure your rear is centered it will make a difference.
Old Mar 29, 2010 | 07:17 PM
  #284
GIZMO's Avatar
The master cylinder is a Strange/Mopar. I purchased a kit from one of the vendors on here. All of the brake lines were fabricated at home from a roll of GM tubing.
Old Mar 29, 2010 | 07:35 PM
  #285
AChotrod's Avatar
Sweet! I have no prob using a BFG, its the cutting that scares me.
I also think Jakez28 sells a Strange manual master and abs delete kit. You can find him on LTXtech.com
Old Oct 14, 2010 | 09:05 AM
  #286
GIZMO's Avatar
Stock internals no more!! The white car is getting a new motor!
Checking the short block.
Checking the combustion chambers.
Installing the heads.
The finished long block.
This is an NHRA/IHRA Stock Eliminator LT1.
Stock crank
Manley rods
Ross .060 stock replacement pistons
Bullet stock lift cam
Old Oct 14, 2010 | 09:16 AM
  #287
ulakovic22's Avatar
Thanks for bumping your thread Gizmo, great project and build thread.
Old Oct 14, 2010 | 09:36 AM
  #288
GIZMO's Avatar
Originally Posted by ulakovic22
....great project and build thread.
Thanks! But, please don't tell anyone about the restrictors, epoxy, and screens that we used in the lifter valley!
Old Oct 14, 2010 | 10:20 AM
  #289
SS RRR's Avatar
Village Troll
removed
Old Oct 14, 2010 | 10:43 AM
  #290
ulakovic22's Avatar
Don't worry, even if I did say something no one would believe me. I'm forever stuck in my 20's and I've never built anything before in my life.
I can't believe you are using them anyway, it's utterly retarded.
Old Oct 14, 2010 | 11:29 AM
  #291
GIZMO's Avatar
edited per Gizmo's request
Old Oct 14, 2010 | 12:06 PM
  #292
SS RRR's Avatar
Village Troll
removed
Old Oct 14, 2010 | 12:09 PM
  #293
96lt1m6's Avatar
Can we NOT contaminate another thread,GEEEEEEEEEEEEEz!
Old Oct 14, 2010 | 12:57 PM
  #294
Revson's Avatar
We used to do something similar on our stockers in the 80's we also used to "block off" the holes under the camshaft in a SBC to keep the oil from running back right on top of the crank.
Old Oct 14, 2010 | 01:07 PM
  #295
GIZMO's Avatar
It seems to help a little. I prefer the breathers over plugs, because they restrict the return flow without creating any extra bottom end pressure. I'm not sure that it frees up a lot of HP, but every little bit counts!
Old Oct 14, 2010 | 01:35 PM
  #296
Revson's Avatar
Yeah, we used to run restrictors in the front and back of the lifter valley, and mess with the return oil flow in the heads. There were alot of little things we'd do hoping they would add up to a few extra horses. Back when I ran we had to run stock springs and on a stick car we'd throw them away after every points meet or national event.
Old Oct 14, 2010 | 02:11 PM
  #297
AChotrod's Avatar
Kids look happy to be working on the car again!! Is this Gumps replacement??
Old Oct 14, 2010 | 02:30 PM
  #298
GIZMO's Avatar
I may drive it a little bit, but mostly we are going to change it to see what it will run with a decent motor.
Old Oct 14, 2010 | 03:29 PM
  #299
1961ba427's Avatar
Any updates to your red firebird/budget build? Think I subscribed to it, but I haven't gotten any email alerts lately.
Old Oct 14, 2010 | 03:58 PM
  #300
GIZMO's Avatar
I am in the process of buying parts at the moment.
