"Stock Internals" Build
Any other ideas on cleaning up wires??
The factory harness is long gone. We replaced it with a Painless set up and Accel DFI. The intake will soon be coverred in wiring when we sart to hook up all of the sensors.
This is what is under the dash (less the harness for the DFI).
I have cleaned up a factory harness before using a set of factory drawings to remove anything that wasn't used. For a race car it is much easier just to replace everything.
New Moser axles with Mark Williams titanium studs.
Installed gun drilled and star flanged axles (The rear also has an aluminum spool, aluminum yoke, and 4.56 gears).
Wildwood brakes.
S & W torque arm with removable crossmember and BMR driveshaft loop.
Finally back on four wheels!
All this get me thinking... wow low 11's with a stock motor, Im on stock motor with 5psi and I still dont get low 11's. haha!
I went to the last NHRA nationals and seen many LT1's running some amazing 1/4 mile times. Great job post up some updates!
I plan on building this myself with a lot of help from some friends. Do you know of any good places to find performance parts for a TH200. I'm looking for a good valve body and things along those lines.
EDIT: Found an answer again randomly searching...
Unfortunately, GM made the slotted converter neck for the TH-200 about 1/16-inch smaller than the "Turbo" TH-350 neck. You would need to machine the pump for the larger shaft and modify the smaller pump gear, as well as a custom input shaft. - In regards to using a TH350 converter with a TH200.
Ready for the bumper cover.
The nose going on.
I know that the last photo is a bit of a tease, but we still have some panel aligning to do before I can post finished front end photos.
